Hey everyone, I did some searching but couldn't find any recent active threads about this: After only 3000 miles I found one of my rear wheels deflated, and when I took it in for repair @ America's Tire (per Tesla Roadside's suggestion), they found a pretty bad crack on the interior side of the wheel/rim. I called my insurance AAA NorCal and they said it's not covered, nor do they have an option to buy coverage for this type of damage, because it's "Wear and Tear" and not a collision, vandalamism, theft, etc-- and this came as a surprise to me. Tesla Service says it's almost $1700 to replace just ONE wheel + tire... and I was speechless for a bit, but it's understandable knowing it's a $95k+ car... but they also don't offer any sort of insurance or warranty for the wheels anymore--- they USED to, but not anymore. So I really don't want this to happen again, or I would love some type of warranty/insurance if it does. -What are my options now? -Anyone's California-based insurance (other than AAA Norcal) cover road hazard damage? -- I might switch over if so and the rates are competitive -Any manufacturer/dealer/Costco (?) offer tire/wheel warranties? I'm even thinking about switching to the 19" - it's $2500 for a full set of 4... and less if I purchase it aftermarket (or completely different aftermarket wheels for that matter). But I'd love to stick with the 21" if at all possible and sustainable. Thanks in advance!!
Sorry to hear about the damage. One thing I would recommend is going with a 19" / 20" set to give you that extra rubber in case of any crazy road conditions. My personal preference is 19" for my winter setup and 20" for my summer set. The tires are cheaper this way, plus you have more variety. 21" & 22" look the best but they come at a price...
To crack a rim, you would have either had to have hit a pothole really hard, or the rim was defective. Did you hit a pothole hard? Was the tire damaged? If it was defective, I would press on tesla to absorb the cost. If it was a road hazard, I would check eBay or the classified section of this forum. 1700 will go a long way towards aftermarket 21's that are better made.
If the damage was caused from hitting a pothole, then that is a collision loss (under Ontario definition) and insurance would cover the rim + a depreciated amount on the tire...however, this would be classed as an "at fault" loss, so you may see an increase in premium (depending on your coverage and rating)...
$1700 is a fair price for a 21" wheel and tire, since the 21" set costs $5500. You may be able to find one wheel from the parts for sale portion of TMC, but I imagine that would take longer.
I run 20" year-round on Avant Garde wheels. The 21s are notorious for blowouts/flats/wheel damage. Go with a slightly smaller wheel size so you have a little more sidewall. Heavy car + tiny sidewall + potholes = nothing good.
As one of the previous posters stated, a crack typically comes from a hard impact to a pothole or other road hazard, or, on rare occasion, a defective rim. If it was in fact from a pothole or road hazard, typically insurance companies in California treat that as a loss under your "Collision" coverage. As this is a very common practice among numerous insurance carriers, I don't see why AAA is hassling you. It's possible that your adjuster at the Auto Club is a new and doesn't know or isn't doing their job properly, so I would highly recommend pushing up the chain of command to a manager. Also a good idea to request a copy of your policy and check under the definition of "collision" coverage.
Thanks for everyone's help. I called AAA again and they will get back to me tomorrow from the claims department. Tesla inspected the wheel and said the tire looks intact but there seems to be an "impact" point on the wheel. I'm not sure what I hit, if anything at all. I generally drive in the Bay Area or sometimes to the Stockton/Sacramento area.. so it might be the mountain roads through the Livermore area. I'm looking into 20" wheels at this point.. the TSW Nurburgring or TSW Donington wheels look good so far.
Hope everything works out for you. Just a side note, since it seems you might have already had an issue with impact damage, be careful with some of the aftermarket cast wheel brands as they have a tendency to be less resilient than even the stock Tesla wheels.
you should join the 'I ordered with 21" wheels not knowing that they would cost me my house in rim damage and blowout maintenance so I switched to 19" wheels' club. there's probably hundreds (if not thousands) of members by now. unless of course you have unlimited funds and don't mind being towed every now and then. otherwise, I highly recommend you switch to a more practical (and quieter and more comfortable) tire/rim combo like the 19s that you should have ordered in the first place.
I agree, switching should probably be considered. You could look at the 19's on other cars if that's the concern. I cracked a rim on my Porsche once. I was quoted about $2,500. Instead I was able to find someone to weld/repair it for $100. Most places wouldn't do it but I found a place that did. I didn't have a problem with it after the fix.
Same problem with the 21" wheels. Seems Tesla either is using cheap rims or it's engineered poorly. No reason cracks should be caused by standard road potholes. Great car, but this was clearly not thought out well.
A word of advice for those getting aftermarket 21's, maybe 20's as well. I was an early adopter of a set of Lexani rims (look exactly like the ones on the Plaid). On the outside at the edge of the wheel it's a sharp edge. Never a thought about it for installing tires and it looks great. But after two flats from going over the steel plates PG&E puts down to cover large holes in the street I started paying attention. That sharp edge cuts the tire like a knife on hard impact. A rounded edge will not cut into the bead area so easily. I have rounded mine off and re balanced the wheels.
21s are a complete fail! They are revenue generators for Tesla, they will leave you stranded, they will cost you a $hit ton of wasted money as @yobigd20 stated, they are heavy (low performance), they require different alignment settings than 19s and 20s, they require adjustable after market rear ULs such as the ones offered by @EVTuning, they are less efficient (reduced range). 19s are the clear winner when it comes to practicality. 20s are are the clear performance winner. Take it from someone who has modded their alignment settings more than anyone else on this forum under the tutelage of the suspension maven - @lolachampcar to achieve ~50,000 service life on each of my first 2 sets of 21s (the 1st set was square, the 2nd set were staggard). I now have ~100,000 on my P85 and also have a LR RWD M3 and a Performance MY. Just because Tesla offers an option on their amazing cars, doesn’t mean that it “works”. 21s on a MS just plain suck, period, end of story! There are many OEM and quality aftermarket options to choose from. Please do your homework before making your next move as I hate to see folks waste their hard earned money. Good luck!
I like the looks of the 21". When I ordered new, I joined the 19" club. My thoughts were to order a set of 20" or 21" true forged wheels one day. Leaning toward 20" because once you you compare ride on of the 19" to the 21", it would be hard to go 21". IMHO... m
The OEM TEsla 21's for the S are the Arachnids. They are forged. Lighter and MUCH stronger than cast allow. Ive had zero issues with mine.
I changed to true forged 20" this year. Wish I had done it a long time ago. Proportions are just right to my eyes and leave enough comfort for me as well.
