21" Wheel/Rim Damage (crack and leak) - Options?
Discussion in 'Model S: Driving Dynamics' started by chang, Jan 12, 2015.
  1. HYonet
    HYonet New Member
    Lost Angeles
    I've noticed that guys who drive Lamborghinis on city streets drive slowly...
    A set of wheels for them are upwards of $30k.
    I had a cracked wheel that got nicely welded and permanently repaired, with no further issues whatsoever.
    I tried the cheaper tires, but they don't survive even the slightest pothole.
    The recommended tires are practically steel walled, and help support the weight of a Model S (approx 4,600 lbs)
    for less sidewall squeezing (and therefore far less puncturing or cutting).
    My best recommendation: get an actual spare wheel and tire, and keep it at home.
    When a tire does eventually go out, you won't be totally screwed.
    Also, buy one of those heavy-duty tire jacks, and you'll be able to switch out your own tire and wheel easily
    and be back on the road quickly, giving you time to buy a new tire and get it put on the wheel.
  2. Hblick48
    Hblick48 Member
    Folsom, CA
    I owned a wheel repair shop for 10 years before I sold it. With larger wheels there is less rubber between the wheel and the road, thus they bend and crack more often.
    Half of that business was repairing bent and cracked wheels. I've personally successfully straightened and welded on thousands of wheels. The other half was powdercoating.
    Google "wheel repair near me" My shop is located in Sacramento, Kwicksilver Wheel Repair. New owners would most likley be able to repair the wheel.
  3. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County, Virginia
    I dumped 21's on all 3 of the Model S's we have owned. Currently running on Titan7 mono-block forged 19 x 9's with stock 245 45VR19's... haven't had an issue since. Lifetime structural warranty and dropped 10 lbs per corner from stock 19's.
