Those with D cars, and 21" wheels, especially who moved from S to D .. do you feel that D cars are wearing the 21" lesser? Or about the same? TIA!
About 3K miles on my 21x8.5s. Despite -1.5s on the rear cambers, I just measured 13/32nds inside to out on front and rear.(new spec is 10/32nds). So yes, it's not a lot of miles yet but it's obvious that I won't experience the 5K miles per set some are reporting plus I get to rotate since I'm square. I have about 21K on my 19s and they measure 8/32nds inside to out on front and rear as well.
FWIW - replaced RF tire on S90D today and inquired how my tires are doing? Staggered 21" Conti SIlents at 15,114 mostly freeway miles......pretty even. -Torqued wheels to 175 NM - Adjusted tire pressure to: 45 PSI front, 45 PSI rear. - Measured tire tread depth at: (Outer) (Center) (Inner) LF: 8/32 8/32 8/32 RF: 10/32 10/32 10/32 LR: 8/32 8/32 8/32 RR: 8/32 8/32 8/32
@NikeWings do you know how work out was the RF? Your other tires seem pretty even, strange that one tire had to be changed so soon!?
Blow out from a night time encounter with an unforgiving pot hole. Otherwise very pleased, as so many told me to expect 10k miles max.
