22” Pirelli Scorpion - Best PSI
Discussion in 'Model X' started by ALLMYNE, Oct 4, 2017.
Tags:
  1. ALLMYNE
    ALLMYNE Member
    Charlotte
    Hi......I understand the suggested cold temp PSI is 42 for these 22” tires and max is 50
    Making a 7k mile road trip starting thus weekend and intrigued if there are any benefits to adding a few more PSI or if I should just set at the recommended 42?
    Ty
  2. Xtek
    Xtek Member
    Seattle, WA
    More PSI should reduce rolling resistance making it slightly more efficient, however you run the chance of uneven wear on your tires.
    Mine was 42 when filled at Phoenix but when I was in Goldendale, WA and it was 40F outside they were down to 36 so take temp into consideration.
