220 charger from 110 voltage
Discussion in 'Supercharging & Charging Infrastructure' started by johns258, Mar 26, 2012.
  1. johns258
    johns258 Model S Signature 998
    Sanibel, FL
  2. vfx
    vfx Well-Known Member
    CA CA
  3. johns258
    Sanibel, FL
    Thanks very much! I'll get one in anticipation.
  4. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Remember that you can only get 24amps, and the two plugs you use have to be from different phases on separate breakers.
  5. ggr
    ggr Expert in Dunning-Kruger Effect!
    San Diego, CA
    Scott451 built one. It works fine, so long as you can find two reachable outlets that are on different circuits and opposite phases.
  6. Trnsl8r
    Trnsl8r S85 2012-2018, X90 since 2016, 3 since 2018
    San Jose, CA
    Get a heavy duty extension cord from Home Depot?
    Still, doesn't seem like a sensible long-term solution...
  7. dadaleus
    dadaleus 4GETOIL P85#S70,FdrX,S85D
    Solana Beach, California, United States
    how can you know you have opposite phases? Is there a way to check? If you're wrong do bad things happen?
  8. Dave EV
    Dave EV Active Member
    San Diego
    The Quick220 will let you know if you've plugged in to split phases or not by lighting up a little LED.
    Otherwise, you have to know which circuit breaker feeds each outlet and then know which circuit breaker is on what half of the phase. Typically breakers next to each other and breakers opposite of each other are on different halfs.
    If you're wrong - you get zero voltage potential between the 2 hot leads since they are in sync instead of the 240V you would expect.
  9. Larry Chanin
    Larry Chanin President, Florida Tesla Enthusiasts
    Sarasota, Florida
  10. TEG
    TEG Teslafanatic
    I built one for myself that I can use with my LEAF. I put a Volt meter into the box. So, if both 120V are the same phase, the meter reads 120V, but if I find different phases then I see 240V.
  11. Larry Chanin
    Sarasota, Florida
    In what circumstances do you plan to use this device? Indoors and outdoors? Only at known locations where you are confident regarding the wiring? I'd be a bit leary of running long extension cords and connecting them overnight.
    Do you think that such a device would work equally well, or be as safe, with Roadsters, Model Ss versus the Leaf?
    Thanks.
    Larry
  12. Dave EV
    San Diego
    Like TEG, I built my own as well. Lots of detail on how to do it in this thread on mynissanleaf.com: My Nissan Leaf Forum View topic - Do It Yourself: 240v from two 120v sources
    If you're not comfortable working with high voltage, I don't recommend you build your own but pay the quick220 guys to do it for you!
    I plan on using it in areas where there aren't any handy 240V outlets and charging at 120V/12A will mean too long a wait.
    I would make sure the box stays indoors - at least mine isn't outdoor rated.
    Aim to have both plugged into 20A circuits which is safe for up to 16A charging. Garges, laundry rooms and kitches are good locations for finding 20A circuits, although they can't be GFCI protected as the device will trip GFCI since it only uses the hot line from each circuit thus leading the GFCI to think there's a large ground fault since no return current goes over the neutrals.
    On 15A circuits, limit current to 12A (though in theory 16A is OK for short periods of time).
    As always make sure the receptacles are in good shape - I would limit extension cord use to no more than 25ft.
    With a volt meter in the device one can check voltage drop when the car starts charging which services to verify that wiring is OK!
    There really is no more issue using one of these than using L1 120V charging - the amount of current pulled through each is similar - so if you are confident charging on each outlet at 120V/12A, then you are good to charge 240V/12A and are able to charge twice as fast.
  13. dadaleus
    This is cool. Totally going to get one of these. Thanks for bumping this thread as I had never heard of this. Will be really useful for times like when I drive to my parents house where there is no convenient 220 outlet. I would imagine this may prove useful when traveling and staying in a rental cabin or such as well. Hotels are the other place I always which has connections, but that would probably be harder as they get nervous about extension cords running all over.
  14. TEG
    TEG Teslafanatic
    24 amps? Not usually. Many 120V household outlets have only a 20A breaker (or fuse). Generally, I don't think you would want to use this device above 16A.
  15. Lloyd
    San Luis Obispo, CA
    Most household wiring has #14 wire which is rated 12 amps each continuous duty. Pushing this has the potential to start fires. Please be careful and don't burn your house down. That would be really bad press!
  16. smorgasbord
    smorgasbord Active Member
    SF Bay Area
    I know of at least one person who carries a set of 220volt circuit breakers and some wire with a 14-50 outlet at the other end. He pops the cover off the breaker box (which in CA is usually near the garage), inserts the circuit breaker and viola - instant 220 volt, high amperage outlet for use with the UMC.
    Of course, this doesn't meet code so you'd be in double trouble if you burnt the house down...
  17. hcsharp
    hcsharp Active Member
    Vermont
    I built one of these with a voltage meter and a switch. The meter is good for monitoring voltage drop and line quality and of course finding opposing phases. The SPDT switch with off in the middle switches it from 240v to 120v so the same device doubles as a 120v solution if you ultimately don't find two plugs within reach on opposing phases. The biggest problem I have using this thing is finding two outlets that aren't GFCI.
  18. daxz
    daxz Member
    Denver, CO
    Does anyone know if you could bridge multiple 240V 50Amp connections? There are RV's with dual 14-50 plugs (100Amp Total) and campgrounds with multiple plugs together.
    Use 2 or more 10kW charging boards using different 14-50 outlets producing the DC voltage for charging and bridging them together (and add EVSE circuitry).
    This is how I understand that the supercharger works using 9 x 10kW charging boards on 3 different phases - so it would be a small scale supercharger from multiple single phases.
    It would be nice if there were multiple plugs already on car for this and dual chargers could be utilized without the high power wall connector .
  19. jerry33
    Texas
    It sure would. If there were two plugs, that would make even 110V charging happen overnight.
  20. Kipernicus
    Kipernicus Model S Res#P1440
    Belmont, CA
    I was checking out my brother in law's house this weekend, and all the outlets by the front door and in the garage are GFCI. I guess this is common practice in newer homes for any outlet near water. We're not about to have extension cords keeping the door to the garage open and running around the inside of the house, so I think I will need to (a) stay 2 nights and trickle charge, or (2) go shopping or have a meal at a place with a level 2 charger and trickle charge to top off. Kind of a pain but not a deal breaker.
    Speaking of breakers, their house panel has no space left, so I won't be installing an extra 220v outlet in their garage.
