220V adapter for Airbnb - would that be helpful?
Discussion in 'Model S: Battery & Charging' started by BNBStudio, Mar 1, 2021 at 3:29 PM.
  1. BNBStudio
    BNBStudio New Member
    Monday
    Texas
    I'm an Airbnb host and I have a 220 volt plug in the garage. Can I buy an adapter for the outlet for Tesla owners to use when they stay at my property? Would that be valuable as a guest or is that too slow? There are only two hotels that have EV charging in my town of 150,000.
  2. beatle
    beatle Member
    Springfield, VA
    You're better off getting a wall unit that provides a J1772 connector. These are more universal and will allow other EVs to charge. Teslas can use J1772 plugs with their own adapters. Don't pigeonhole yourself to only Tesla customers. You can look for "level 2 chargers" on Amazon to start. Most will have J1772 connectors. (Technically they're not really chargers, but that's a pretty pedantic conversation for this thread.)
    In the meantime, just listing what kind of receptacle you have will be useful for EV owners. Many people have adapters for their own mobile connectors to plug into various kinds of receptacles without needing anything on the wall.
  3. DerbyDave
    DerbyDave Member
    Kentucky
    I agree with what Beatle said, but it is more expensive. In the meantime, for $35, you can get a Tesla adapter for your receptacle. You can see each plug design by selecting the various plugs in the pull-down window at Gen 2 NEMA Adapters
    It would also be good to mention the type of receptacle you have and its voltage/amperage when promoting it, and I think it would be beneficial to have either an adapter, or, as Beatle says, a J1772 Wall Connector. Thanks.
  4. beatle
    beatle Member
    Springfield, VA
    I didn't even think of providing a UMC adapter for Tesla owners. That's also a good, inexpensive option in the short term.
  5. kavyboy
    kavyboy Active Member
    Spring, TX
    I can't add much to what's already been posted other than to say yes, it would be helpful.
    Also, you could add yourself to plugshare.com.
  6. DMC-Orangeville
    DMC-Orangeville 85D and John Deere 5100E
    NW of the 6ix Canada
    #6 DMC-Orangeville, Mar 1, 2021 at 4:19 PM
    It also depends on the type of outlet, and if your customers have access to the receptacle.
    One of the most common 240 volt receptacles is a NEMA 14-50 "Stove". It's common in campgrounds, houses etc. It's usually on a 50 amp 2 pole circuit breaker - making it good for 40 or 32 amp charging. Tesla customers can buy an adapter for their car (a lot do that), and it comes as standard equipment in several other makes (EG Volvo XC40, Audi E-tron, etc). If it's a different configuration (eg NEMA 14-30 "dryer") it's not as likely that your customers will have an adapter.
    Do you want your guests to have access to the garage? If not and/or the receptacle is not a NEMA14-50, you may wish to heed @beatle 's advice, and buy an inexpensive J1772 EVSE, and have an electrician wire it outside of the garage. ALSO - Some of these EVSE' come with a 14-50 or a 6-50 "welder" plug installed on it. If the receptacle is one of those, you could just plug it in.
    - and make sure that you promote this via Plugshare, website etc.
  7. Rogue Synapse
    Rogue Synapse Member
    Asheville, NC
    Lot of us out here with Gen 1 chargers. Gen 2 adapter would eliminate most model S and X over a few years old.
    If you don't want to invest in a level 2 EVSE (agree with that recommendation as it would be helpful for non-Tesla EVs as well, which hopefully there will be more and more), I would just advertise what exact type of outlet it is (e.g. NEMA 14-50, 6-50, etc) and say that EV owners are welcome to plug in with their own adapters.
    EVSE ("Chargers") start at around $300-400 though, so it's an investment. But I have made decisions about where to stay in the past based on charging availability. I actually stayed at a VRBO just this weekend which allowed me to use their dryer plug just inside from the carport to charge my Tesla (using my own adapter).
    Here's an example of a good, lower-priced level 2 EVSE that all EVs would be able to use (including Teslas with their adapter, which most Tesla owners have:)
    https://www.amazon.com/Grizzl-Level-Charging-Station-Output/dp/B07XSB5K6G/
  8. DerbyDave
    DerbyDave Member
    Kentucky
    In addition to the Gen 2 Adapter I suggested in my first post, you can also buy the appropriate Gen 1 adapter for Tesla vehicles built from 2012 to late 2017 for $45.
    Gen 1 NEMA Adapters
    With a Gen1 and Gen 2 adapter, this is an inexpensive way to provide all Teslas with connectivity to your existing receptacle. You can add the built-in wall connector and additional wiring which would be required later.
  9. BNBStudio
    Monday
    Texas
    If I had the 14-50 setup, would that only be advantageous to Tesla owners but not other electric vehicle owners?
    How would I figure how much that will add to my utility bill? Wondering if that's an expense to absorb or if I raise my prices.
    I just had a guest recommend I offer it since there are so few options in my town.
  10. beatle
    beatle Member
    Springfield, VA
    Other EVs have 14-50 adapters as well (it's a popular plug as others have stated) so your bases are covered.
    As for your utility bill, it will really depend on how many people use it and whether they stay multiple days and use your place as a base camp for really racking up the miles. For reference though, most cars will use 60-80kwh when charging from near empty.
  11. mswlogo
    mswlogo Well-Known Member
    MA, NH
    You can put a power monitor on that one outlet fairly cheaply, including monitoring it remotely.
    I would recommence a Sense with an extra set of Coils you add to that circuit.
  12. Lasttoy
    Lasttoy Active Member
    St Augustine, Fl
    I put in a 14.50 (50amp), for my buddy. He's very happy, had different types of cars renting his bnb now.
  13. BNBStudio
    Monday
    Texas
    I see now that my outlet is a 14-30, not a 14-50.
    I found this thread which was very helpful in thinking about the costs. Vacation Rental Charging?
    I like the idea of the wall unit J1772 EVSE with 50amp. Have to research wall units now and call my electrician.
    Thank you, everyone, for your help!
  14. Rogue Synapse
    Asheville, NC
    Yeah, but this would only cover Tesla owners and not other EVs
  15. DerbyDave
    DerbyDave Member
    Kentucky
    The original post was specifically about Teslas. There is a cheap and simple fix to use an existing outlet for Tesla charging. One can, of course, add other EVs and billing and more power, etc. -- for additional expense.
  16. ucmndd
    ucmndd Well-Known Member
    Just advertise the availability of the plug and the type of receptacle. No need to overthink it. I regularly search for listings that mention EV charging capability and I’m certain others do too.
  17. cwerdna
    cwerdna Active Member
    SF Bay Area, CA
    Yes.
    I wouldn't go for the cheapest random Chinese or no-name L2 EVSEs you can find. If I didn't care about fancy features but wanted quality, I'd go with Level 2 Electric Vehicle Charging Stations: 12-80 Amp | ClipperCreek.
    No. What I wrote at Adding Charger at Work is still true for me. I've been driving BEVs as my primary car since end of July 2013. I haven't had an ICEV in my household of 1 for over 2 years now. I've never had anything that can plug into NEMA 14-50.
    As I posted at Why ChargePoint is Terrible, many vehicles do NOT come with any EVSE that can plug into NEMA 14-50.
    Even Tesla stopped including the NEMA 14-50 adapter awhile ago.
  18. DMC-Orangeville
    #18 DMC-Orangeville, Mar 2, 2021 at 11:07 AM
    Well.....the Audi e-tron, e-tron Sportback, and Volvo XC40 electric all come with a NEMA 14-50 plug, as standard equipment. I just test drove them yesterday, and they all come with the charge kit.
    However - if the receptacle is a 14-50 (OP hasn't identified it other than it's "220 volt"), They would be better off buying a plug in EVSE J1772. It fits everything.
  19. Rocky_H
    Rocky_H Well-Known Member
    Boise, ID
    Actually did:
    There is an easy thing you could do with this, but it's a little spendy.
    Clipper Creek makes excellent, rock solid charging units that are made in the USA. This can plug into your 14-30 outlet and hang on the wall, and it provides the J1772 plug that can work for all electric cars. But it's $485. And maybe that's not a bad deal for a long term solution.
    20A Level 2 EVSE LCS-25P with NEMA 14-30 | ClipperCreek
  20. Big Earl
    Big Earl bnkwupt
    Springfield, VA
    Clipper Creek also offers budget options through a brand called Amazing E. They have a 16 amp EVSE with a NEMA 14-30 plug for $329 ... I have a friend with one and it's very high quality. Charge speed won't be great at 16 amps vs 20 or 24, but it should be sufficient for most overnight guests. Tesla owners with their own 14-30 adapter could unplug the Amazing E and get the full 24 amp charge rate with their own mobile connector.
    Home EV Charging Station, Level 2, 240 Volt, 16 Amp or 32 Amp
