221 Rated Miles - 60D
Discussion in 'Model S: Battery & Charging' started by Hota, Aug 12, 2016.
  1. Hota
    Hota Member
    New England
    I charged my 3-week old S 60D to 100% for the first time two days ago and got 221 rated miles!
    Typically I set the charge limit to 95% and I get 209-210 rated miles.
    I hope it stays that way!
    • Informative x 3
  2. MikingCO
    MikingCO Member
    Colorado Springs, CO
    My new 60D charged to 220 the other night. I charge to 100% every chance I get and the highest I had seen was 219. Hmmmm
  3. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    It won't stay that way. The displayed battery capacity figure will likely decrease 1 or 2% in the first year or so. That's normal.
    Definitely not recommended. Your battery will degrade faster if you do that.
    • Disagree x 1
  4. MSullivan
    MSullivan Member
    New England
    I think it has been decided anyone with a 60 that has a 75 kWh battery onboard can safely charge to 100% on a daily basis.
  5. Mickie
    Mickie Member
    Chicago
    Yeah but my DS told me 90% is the safety point, per Tesla engineers, so I don't know what the hell to think and just play it safe :/
  6. plankeye
    plankeye That Vegan EV Guy
    Frisco, TX
    I think at least one 60 owner needs to be a guinea pig and always charge to 100% and see if they have more/faster degradation than those only charging to 80-90%.
  7. MikingCO
    MikingCO Member
    My charge limiter is and has been set to 100% since I got the car. I have no intentions of dropping it unless Tesla (not some random at a service center) comes out with some official notice stating that it will harm the refreshed 60 battery. So I'll be the guinea pig :)
  8. Mickie
    Mickie Member
    Chicago
    But! Has Tesla released a notice stating it's ok to charge it to 100% daily?! If they haven't, I'm forced to assume the partial charge recommendation stands, giving more credence to the random punk at the SC :confused:
  9. Buddy
    Buddy Member
    Riverside County
    Some on this forum have said their DS told them it's okay to charge to 100%. I doubt I can find that post but it la either in the charging thread or model s delivery thread I assume.
    Also people have confirmed that the new 60 doesn't taper off when charging to 100% while supercharging. That is taken as evidence that the "100%" is not the batteries full charge. If that is true then charging a 60kw is really just driving around a model s 75kw with a battery limited to about 80% charge.
  10. Buddy
    Buddy Member
    Riverside County
    I realize I didn't cite anything but if your really curious it's on this forum somewhere...
  11. Mickie
    Mickie Member
    Chicago
    I've read all that, and believe me my gut tells me it's true as it makes too much sense. I guess I give in too much to shadows of doubts. Granted I barely need to charge and could get by on 110V at the moment, once my other cars sell that can change very quickly.
  12. plankeye
    Frisco, TX
    Great! I was just about to ask about the charge tapering before reading your post. That's great to know, and great for the new 60 owners.
  13. Fiver
    Fiver Active Member
    Utah
    I think it also really has to do with your driving habits. If you need 221 miles for your daily travels, then go for it. If you don't, then no harm in charging to 80 or 90% or whatever Tesla "recommends".
  14. GoTslaGo
    GoTslaGo Learning Member
    NV
    For those of you with the software limited 60s, have you ever gotten the charging to 100% warning (paraphrased: "charging to 100% may damage the battery") that others have seen?
    E.g--
    Firmware 7.1
    Post #3834
    Just curious, thanks in advance!
  15. chillaban
    chillaban Active Member
    Bay Area
    I definitely get that in my software limited 70, though from time to time I set it to 93% in order to squeeze in one more commute based off the math that 94% of the 70 is 90% of the 75.
  16. Mr So Chill
    Mr So Chill Member
    Maryland
    Yes. I have gotten that message a few times. I ignore it and contribute that message to the fact that the warning was integrated into the system before software restricted batteries were an option. I charge to 100% whenever I can. My primary source of charging is 110v.
  17. nexsuperne101
    nexsuperne101 Member
    London, England
    So does it actually do 220 miles to a charge? If so, how fast are you driving? I know with my Leaf, 50mph gets 40% more miles than 70mph driving does.
  18. Mike K
    Mike K Member
    Los Angeles
    If it can be determined that Tesla is spreading the 60kwh capacity over all of the cells and not turning off specific banks of cells than I can't see how it would be detrimental at all to charge to 100% on a 60kwh car. I think that's what makes it such a great value over the 75. You can charge to 100% all the time and only end up with 10 - 15 less rated miles than a 90% 75kwh charge.
  19. Hota
    Hota Member
    New England
    No not even close. I use a 1.2 speed factor on evtripplanner and it's spot on though.
  20. nexsuperne101
    London, England
    I doubt that Tesla are turning off any part of the 75KWh battery when it is in 60KWh mode. All they will do is limit the charge voltage to 3.9 volts per cell (max voltage of 4.2V, minimum assumed at 2.8V) to get the 20% capacity reduction. Leaving certain cells dormant would never work with longevity.
