227 wh / mile in my P85D.....
Discussion in 'Model S: Battery & Charging' started by sorka, Apr 17, 2015.
  1. sorka
    sorka Well-Known Member
    Merced, CA
    Drove from Bellmont, CA to Alviso, CA over 19.5 miles no elevation change. Speed was slow but steady at 55 to 60 mph.
    Then on my way home last night on my 130 mile commute, I averaged 282 wh / mile goin 65 to 70 with a few passes up to 85 and 4 full power launches during the last 6 miles after getting off the freeway. Before those, my average had been 278 but my playing around after exiting the freeway ruined it a little.
  2. dirkhh
    dirkhh Middle-aged Member
    Portland, OR, USA
    That's mighty impressive.
    You haven't entered your data into the Firmware Upgrade Tracker, so I can tell which build of 6.2 this is - but the speedometer to 160 makes me think .153 or newer.
    I have 2000 miles on mine, averaging 359 Wh/mile - and .153 has not really made any difference for me.
  3. sorka
    Merced, CA
    Yes. It's .153. Is there a more recent update than that?????
    BTW, my normal commute home over the last two and only two times was around 300 wh / mile. So this is odd as I didn't change my driving. The temperature was about the same. No wind. Elevation up about 150 feet.
    The only thing I can think of is I just had Xpel Ultimate applied the entire front of the car. It's very very smooth and slippery. Could this have had an effect on drag?
    - - - Updated - - -
    Oh and that average included an extra exit and enter onto the freeway for a supercharger pit stop.
  4. dirkhh
    Portland, OR, USA
    .155 / .160 / 101.36.2 (no kidding)
    It could indeed.
  5. sorka
    Merced, CA
    Nobody has talked about or mentioned anything past last week's .153 update. Where can I find out about these?
  6. dirkhh
    Portland, OR, USA
  7. ra-san
    ra-san Member
    San Diego, CA
    #7 ra-san, Apr 17, 2015
    Doubt it'd be particularly measurable and nothing like the big number changes he saw.
    Don't know how you guys manage the numbers here really. I know, with your right foot mostly :). I know the methods, but am impressed with you being able to do them well enough to see these numbers.
    For reference, my near 700 mile trip averaged 369wh/mi between San Diego and St George UT. We drove prevailing speed of traffic (but that's 70-85+ for a lot of those stretches). My overall average is still over 400, and I have xpel ultimate over the whole car :). The overall has a lot of mostly start stop short in-town stuff though, which given my fondness of not speeding, but getting up to speed fast, makes sense. Rarely use the brake, but don't try to minimize regen except on freeway.
  8. brianman
    brianman Burrito Founder
    19" cyclones, sorka?
  9. sorka
    Merced, CA
    Sorry. Should have mentioned that.
    No, regular 19s at 50 psi as that is what the door sticker now says and that's what the factory put in it at delivery. I did a double take until I checked the door sticker.
    Also, those miles are with the suspension on the lowest setting. Raising the car to standard increases the usage by about 5%. Really glad I got the air.
  10. brianman
    Yah, 19s with 50 should definitely help.
    - - - Updated - - -
    Also, @dirkhh - "Merced, CA" vs. "Portland, OR".
  11. sorka
    Merced, CA
    My lifetime average had been about 300, but the two days prior to this photo, I gave a good 30 miles of demos with lots of launches with range mode off. My average quickly climbed to 325 but has since settled back to 315.
  12. jerry33
    Texas
    Upgraded to 6.2 (.153) a couple of days ago and it does seem as if Wh/mi is lower. Of course, two days isn't enough to really tell.
  13. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    This is the primary reason for your good numbers. Next time you're driving through fog (if you get it that way), look at your numbers. You'll see they're very low, since fog is present in very calm meteorological conditions.
    Calm winds will generally mean good numbers (although not as good as a tailwind!)
    The Xpel probably has a very small effect on drag. Paint with clearcoat is also smooth and slippery.
  14. Cottonwood
    Colorado
    Not quite as good as 227, but here is 237 Wh/mi over 302 miles in a P85D. I did have a tail wind...
  15. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    Almost as good as my P85 :) but not quite
  16. FlasherZ
    My P85 got ~270 Wh/mi (lifetime avg for me is 350) yesterday for a trip to St. Louis and back, mostly 70 mph. I have .124.
    Compared to what I've gotten in previous years for equivalent ambient temps, it does seem this year my Wh/mi figure seems to be a bit less.
  17. dirkhh
    Portland, OR, USA
    Finally a trip with outstanding consumption. 23 miles, about -300ft. Temperature in the high 60s, no noticeable wind. Mostly freeway but rotten traffic, so a good part below 50mph (which likely explains the good result): 248Wh/mile
