I don’t know what you mean. There is no HUD in any Tesla.Used '16 X is about $50K now. They're dropping too w/ the recent price cuts.
I thought you meant the HUD
Commonly referred to as the Instrument Cluster Display or ICD. But no, the images are displayed on main screen. That is the right screen to use, IMO. but the blind spot view is in the lower left of the display and not movable on the X. If would be perfect if I could move it to the top of the display, much closer to the line of view of the rear view mirror, plus its view is more closely related to the rear mirror anyway. If it appeared on the ICD, that would require a large move away from the mirror, to check it. Plus it would likely have to cover the Nav Map, which might not be good, when maneuvering around.i meant in front steering wheel X/S
So, I've got a 2020 Model Y and a 2022 Model X. Some of the issues between the cars goes out the window because of the changes that have occurred with the Model Y as of late.
What has changed in the Y since 2020: heated steering wheel, a revamped center console, HEPA filter/biohazard mode, AP hardware, 4680 battery cells, revamped suspension off the top of my head.
In the latest Y, you essentially get a more usable package - you're able to install roof racks, have a bit more weight for bikes if you're using the tow hitch without the complexity of the X. You cannot install any roof rack on the X simply because of the design of the falcon wing doors. The ride in the 2020 Y is stiff, but I understand that they've changed it late in 2022 so it's supposed to be better and more comfortable. I have yet to try it, but if it's a serious change it might have swayed me away from the X.
While the X is certainly more comfortable, it's a mixed bag - you can tow more but because of the design of the tow hitch, it actually has a lower weight capacity (160 pounds for the Y, 120 for the X). I've got the 6 seater, so it should be more comfortable overall, however, with the way the seatbelt buckle intrudes into the seat cushion it can make sitting in the middle row uncomfortable. You cannot fold that middle row in the 6 seater either, so if you want to carry a lot of stuff or large things, you might not be able to. In the 7 seater, it's a 60/40 split for the middle row, which means you can't have long objects such as skis in the middle (since you cannot really carry it elsewhere) and still carry 4 passengers unless you split it left or right instead of front vs back. In the Y its a 40/20/40 split. Seats are wider in the X but could use better side bolstering and well as better thigh support. The X is easier to get into and out of, especially with the FWD.
It's better to have the additional Instrument Panel in the X as well as the larger main console screen, but you give up physical stalks that I think are a mistake at this point (FSD really needs to be Level 4 before they did this). It's quirky at best using the turn signals (although the auto cancel is a nice feature), and hate the screen controls for gear selection. I've had too many times where it doesn't engage the gear because it didn't like the way that I swiped it. I've had to swipe up to 3-4 times in a row to finally get it to engage, which when parallel parking on a busy city street is unacceptable. Same thing for the turn signals in that I've hit the wrong button and put on the opposite turn signal - I've never made that mistake when using the stalk controls. The yoke is okay, but it's always a question of what happens in that 1% instance of an emergency maneuver and whether you actually grab the wheel or catch air instead (hit or miss).
So, overall, they're each nice cars but also have compromises to deal with (at least until the suspension is sorted out with the Y). As more competition comes to market, it'll be a harder sell simply because of some simple things Tesla has decided to revamp that nobody asked for.
I just traded in a ‘22 X for a ‘23 Y on 12/30/22 partially because the X trade-in value was very close to what I paid for it and the Y was on sale. I made the right choice despite recent price drops because the X trade value would have also dropped.Revamped suspension on Y more "cushy" vs X?. I hate my bumpy 3 on rough roads.
Anyway, I don’t notice hardly any difference in the suspension, if anything the X was a little bouncier (set to auto). I previously had a ‘18 M3 so I know about the Tesla’s harsh suspensions, but the Y is very comfortable.
The X is not worth the price difference compared to Y imo, unless of course money is just not an issue!
I never thought the center mounted display was an issue in the 3 or Y. Many Toyotas (and others) for example, have center mounted displays, with nothing directly in front of the driver.ICD got it. I've seen some aftermarket ones for 3/Y but not quite the same. I don't miss it as much as I thought I would but that is one of factors that is a + in my X column
My old Prius Prime was like this, BUT it had a HUD, something which I found sorely missing when we had our MYLR. I added an instrument screen to it but that was very hard and buggy.I never thought the center mounted display was an issue in the 3 or Y. Many Toyotas (and others) for example, have center mounted displays, with nothing directly in front of the driver.
As someone whos had the old X and new Y, I would no question take a new Y over an old X.More used X drops. Put in my Y order for tax credit just in case but still shopping till 3/1
X Price decreased Price went down by $10,000 to about what i'm paying for new Y
Used Tesla Model X for Sale in Peoria, AZ - CarGurus
Save $14,982 on a used Tesla Model X near you. Search over 1,400 listings to find the best Peoria, AZ deals. We analyze millions of used cars daily.www.cargurus.com
Out of warranty issues
New Y has more range
New car vs old
Better and faster UI/computer
And importantly the old X maxed out at like 150kw charging speed? The Y and new X not only go to 250 but has a taller curve. You will supercharge way faster with a new one vs old on roadtrips
Yes, for Level 2. You can max it out with the appropriate 240v/80A wall charger, although they don't make them anymore, otherwise it means nought since most only push 240/50A at most. Now, that said, I think there was something said that high charging leads to battery degradation. You'd have to find someone who has this particular combination and ask them if they've seen it.I guess the only thing going for the X is style/looks
Warranty I would resolve by buying an aftermarket product or buying thru TSLA
Does Dual charger make a difference for SC speed/curve?
The dual chargers is for AC-to-DC charging, by my understanding of it. Superchargers are DC-to-DC and thus why the can go at a higher rate - it bypasses the onboard charger. How it all works - still is magic sorcery to me. Onboard ChargerElon poopooed that degradation to speed hypothesis. But I only push 30A at home regardless.
SC is a different animal. There I want the "safest" and fastest charge and my '19 3 SR can do 250Kw but not for long curve. I thought the dual charger would help at SCs too, L2 I don't care about as much
Further to this, the dual chargers aren't available on newer models, so the idea that it would help, despite that the newer cars can achieve a higher charge rate really means that the onboard charger is bypassed at SCs.The dual chargers is for AC-to-DC charging, by my understanding of it. Superchargers are DC-to-DC and thus why the can go at a higher rate - it bypasses the onboard charger. How it all works - still is magic sorcery to me. Onboard Charger
I think the change happened some point in 2018. I had the dual chargers in my 2017 S, which only came to use at a couple of chargers somewhere deep in NJ. Otherwise, I never really had an opportunity to exploit it as there are few 80A Destination chargers around.Thanks. That link helped. I think of it as hoses of water.
I guess i'll have to wait longer and more often at SCs with an older X. When did they update/refresh ?
It's coming down to a practical vs looks/space decision...
