An update.
@stopcrazypp, it seems you were spot-on.
CR admitted a few things recently.
1. They set their Tesla to the less-aggressive regenerative braking (this negatively impacts the Tesla more because of its massive weight)
2. They disable "extended range" modes, which presumably means the Tesla-set 90% daily charge limit
3. They made sure both cars had ~2 to 3k of miles only, so should be almost no degradation
That seems to explain it quite readily. Yes...Tesla's get 90% of their range when you set the battery to a 90% charge limit.
S 75D: :CR 235 miles vs EPA 259 miles: 91%
X 90D: CR 230 miles vs EPA 257 miles 89%
The "mystery" has been solved. Their quote:
We make sure the car is in its version of normal drive mode, not extended range mode, because our goal is not to see what’s the maximum range an EV can get when pushed to its limits, but rather to see the total number of miles a driver should expect under normal circumstances.
I don't know what the Chevy Bolt uses? I've seen some people mention a default 90% limit as well and a default 100% limit.
