.24 upgrade Tesla Wall Charge maxes out at 32 amps now instead of 48
Discussion in 'North America' started by SpudLime, Jun 29, 2018.
  1. SpudLime
    SpudLime Active Member
    Leesburg, Va
  2. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Have you tried rebooting and making sure you have 48A set on the screen? If the amps were lowered for any reason it will default to that lower setting the next time unless you manually put it up again.
  3. SpudLime
    Leesburg, Va
    i started the thread for discussion to see if anyone else has had this issue since upgrading.
    The original poster is the one to ask.
  4. SomeJoe7777
    SomeJoe7777 Marginally-Known Member
    Houston, TX
    I charged last night under 2018.24.1, and got the full 48 amps. My HPWC is capable of 80A, it is installed on a 100A breaker.
    • Informative x 2
  5. SpudLime
    Leesburg, Va
    Just realized you cant edit your posts...weird.
    This is for the Model 3, just in case folks didnt follow my links.
  6. Parzival
    Parzival Member
    Houston, TX
    No power limitations here when using HPWC on 2018.24.1.
  7. insaneoctane
    insaneoctane Active Member
    Southern California
    Good news to hear others not being restricted as I was going to hold off the update until I saw confirmation from other people that .24 didn't restrict the charge rate on their model 3....looks like I am good to go.
  8. insaneoctane
    Southern California
    Just suggested that mods move this thread...
    Thread is in wrong forum.... Should be "Model 3: Battery & Charging"
  9. SpudLime
    Leesburg, Va
    sorry, new to this forum. I saw other charging related stuff..
  10. gaswalla
    gaswalla Model S,3,X.. CT with Austin delivery
    San Diego
    What sort of charging device are you using?
    I have the exact same experience with my Gen1 UMC... it seems like the UMC had it's firmware updated and now maxes at 32amps on both my Model S and 3.. last month was giving 40 amps to both
  11. miimura
    miimura Well-Known Member
    Los Altos, CA
    If that's true, I won't ever be connecting my Jesla to a Tesla vehicle. I was previously considering using it as the "travel EVSE" for both the RAV and the 3. I guess it will just stay in the underfloor compartment in the RAV from now on. I will have to cut the zip ties that keep the 3's Gen2 UMC cord tidy for daily charging if I ever need to take it with us to a vacation house or something.
  12. mtndrew1
    mtndrew1 Active Member
    Gardena, CA
    My model 3 is charging at 48A on 24.1 as we speak.
    6A065D9A-DFCC-4B08-997B-449FA1ED5248.png E63692DD-BEFF-4E64-809F-AE6B4E1D7768.png
  13. SpudLime
    Leesburg, Va
    latest update?
  14. gaswalla
    San Diego
    pretty sure this has more to do with the firmware on the UMC and the charging device used vs the car and its software.
    The 48amps was prob on a HPWC, which has no issues hitting 48 amps
  15. eprosenx
    eprosenx Active Member
    Beaverton, OR
    So is the report here that Gen 1 UMC units (which should do 40 amps) are now only doing 32 amps? Gen 2 UMC units are only good to 32 amps naturally since that is what they are built for.
    HPWC's should be able to go up to 80 amps depending on what they are fed from, how they are set, and the max charge rate of your vehicle.
    If Gen 1 UMC's are all of a sudden only charging at 32 amps that would be big news.
  16. Killmore
    Killmore New Member
    st-jean-sur-richelieu
    Good day,
    Sorry to ask, but what is the program you are using on this screenshot ? It's exactly what I'm looking for with my futur Model3. I need to know how much money each charge consume so I can pay back my brother :p
  17. SomeJoe7777
    Houston, TX
    This screenshot is from the TeslaFi.com web site. TeslaFi.com will log everything about your vehicle, including drives, charges, supercharges, etc. and keep logs of all of it. Subscription is $50 per year.
