The weather rated Mobile Connector with permanently attached NEMA 14-50 plug costs nearly as much as a Wall Connector.
Wall Connector (up to 48 amps) with 24’ cord: $500
Wall Connector is the most convenient charging solution for houses, apartments, hospitality properties and workplaces. With up to 44 miles of range added per hour of charging, a 24 foot cable length, multiple power settings, and a versatile indoor/outdoor design, Wall Connector provides...
shop.tesla.com
Corded Mobile Connector (up to 32 amps) with 20’ cord: $400
The Corded Mobile Connector features a NEMA 14-50 plug and improved charging speeds in comparison to the Mobile Connector with NEMA 5-15 Adapter. Includes: 1x NEMA 14-50 Corded Mobile Connector - 20’ cable 1x storage bag Corded Mobile Connector Manual Note: The Corded Mobile Connector is...
shop.tesla.com
Sure, you could use the Mobile Connector that comes with the car, but it’s really not designed for daily outdoor use, as it is not weather tight. Both Mobile Connector options are susceptible to theft whereas the Wall Connector is not.
If you decide that the NEMA 14-50 receptacle is the right choice for you, make sure your electrician installs a Bryant or a Hubbell brand receptacle,
not a Leviton brand from your local home store.
Comparing the 2 outlets recommended by Tesla with the sub $10 big box model as well as the one I think you should buy 1. Hubbell 9450a 2. Bryant 9450fr 3. Cooper 5754n 4. Leviton 279-S00 The Hubbell and Bryant are far and away the superior product here and since Hubbell owns Bryant and these...
teslamotorsclub.com
