25 new chargers in Ontario canadian-tire-locations
Discussion in 'Canada' started by richardl007, Dec 5, 2016.
Tags:
  1. skhenry81
    skhenry81 Member
    Toronto
    Damn, $20/hr that's pretty rich. On the brighter side I'm glad they are building the infrastructure....
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I guess this means we finally get the En Route charging stations.
  3. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    That $ 20 / hour is a bit rich. A level 3 charge of 400V DC and 100A would be 40kw / hour = 50 cents / KWh.
    So a Tesla 400km charge would be about $ 40.00
    At current gas prices of about $ 1.00 / litre and a fairly thirsty 10 litre/100km car would pay also $ 40.00 for gas for the same distance.
    A more efficient gas car would only pay $ 25.00
    So what is the incentive to go electric?? Just the feel good for doing something for the environment won't cut it for the masses.
  4. skhenry81
    skhenry81 Member
    Toronto
    EnRoute charging means good bye to range anxiety but they need to bring the cost in line with what electricity really cost. I pay 0.087 cents off peak and 0.18 cent during peak. A full charge at peak pricing is around $15 charging from 0 to 100%.
  5. mrElbe
    Even the most expensive Blink charging net work in the US only charges US$ 9.99 per session for guests and US$ 6.99 for members
    • Disagree x 1
  6. mrElbe
    Not too sure about "good bye to range anxiety". Those chargers will have only one station. If out of commission or currently occupied you are either screwed or in for a long wait to get your turn. Even if the Tesla Superchargers have problems, most likely a few stations at the location are still operable.
  7. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    Wrong: What is the fee to charge at a Blink DC Fast Charger?
    Charging fees are set by kilowatt-hour ("kWh" - a unit of energy typically used by electric utilities) or session, depending on what is permitted by the state, and membership status. We are a proponent of kWh pricing because it is usage-based and EV drivers pay fees based on the actual amount of power consumed during the charging session rather than the amount of time that the car is plugged into the station. Certain states permit kWh pricing and others do not.
    State Member Rates Guest Rates
    California $0.59/kWh $0.69/kWh
    Pennsylvania $0.49/kWh $0.59/kWh
    Oregon $0.49/kWh $0.59/kWh
    Washington $0.49/kWh $0.59/kWh
    All Other States $6.99/session $9.99/session
    The most expensive rate is $0.69/kWh.
    ChargePoint used to charge a per minute fee in addition to a per kWh fee... Now it appears they are just charging $0.40/kWh.
  8. mrElbe
    Correct for those States where charging by KWh is permitted, BUT Ontario does not allow reselling electricity unless you are a utility.
    So, the charge per session is relevant for comparison.
  9. MP3Mike
    Oregon
    But they aren't charging per session, they are charging per minute. Which I think is more comparable to charging for the kWhs used. (As long as you ignore the taper, which makes it even more expensive by the minute.)
  10. Drone Flyer
    Drone Flyer Active Member
    Canada
  11. hingisfan
    hingisfan hingisfan_Mark_V
    Kingston, Ontario
    I've seen 10 and 20 per hour mentioned on different Flo sites.
  12. skhenry81
    skhenry81 Member
    Toronto
    Charging should only be by KWhs used. Anything else is just robbery.
  13. rypalmer
    rypalmer Active Member
    Canada
    As opposed to per minute? Why does it matter?
  14. skhenry81
    skhenry81 Member
    Toronto
    Charging speeds don't remain constant which is a huge factor in how long you will be at the charging station.
    No two chargers charge at the exact same rate. So at the end of an hour one could have gained lets say 200 kms versus the guy that was right beside him who gained 250 kms. Is it fair that they are charge the same amount of money?
  15. mrElbe
    Only charging per KWh or a flat rate per session is fair. Also the charges should be plainly advertised and or displayed right at the charging station.
  16. rypalmer
    Canada
    What about if the EV stays plugged in after charging has finished? Should they be charged per minute then for blocking the station?
  17. mrElbe
    Definitely - Some stations charge you until you hit the Stop button.
  18. skhenry81
    skhenry81 Member
    Toronto
    I agree completely! Charging stations are for charging, if your charge is charged you need to move immediately so the next person can get charged up. You don't see people at gas stations fill up with gas and then walk away to go have dinner and leave their car at the pump...
  19. DMC-Orangeville
    DMC-Orangeville 85D and John Deere 5100E
    NW of the 6ix Canada
    The Flo network standardizes on AddEnergie charging stations/network. (Flo is owned by them). The AddEnergie network allows the owner of the charging station to set the charge for the service.
    They demonstrated their system to me (they tried to hire my company). I was able to change the rate from $1.00 per charge to $1.00 per hour, paid by the minute. I could change the rate too. Flo, the owner of the Canadian Tire chargers, will charge what the market will pay. If $20.00/hr is too expensive, they may lower their rates. I would NOT expect them to sell their power at a loss, as they are a business. They will be paying on-peak rates, delivery charges, HST, and perhaps a demand charge...... 50 KW/Hr for $20.00 is $0.40 per KW/Hr.
    @skhenry81 quotes his Toronto rates....does not include delivery charges, HST, etc (or a demand charge), and is at $0.18 /KWHr. Rural rates are higher too. I'd expect, fully loaded cost may be closer to $.30 per KWHr at these stations, so $.40 is in line with what it costs them in "raw materials".
    In Quebec, the same charge is $10.00, but their hydro cost is much cheaper
    • Informative x 3
