Actually, that is not what I was saying, if you look at my prior post. Your battery charge is accurate already at 256 miles, using the 242Wh/mi scalar. That will give you 62kWh for a full charge.
If you would prefer, you can change the display to %, and that will be better (though you lose resolution, and you also lose the ability to see battery degradation).
You should not be "depending on these readings" - at least not in terms of how far you can go, since it is only very loosely correlated. Think of it as an energy available meter, not a measure of how many miles you can go. You can use that energy to plow snow, you can use it to heat the cabin, you can use it to move rain out of the way, you can use it to sit stationary, you can use it to deform and roll your nice sticky extreme performance tires, you can use it to deform and roll your winter tires, or you can use it by leaving the car in the garage, you can use it to move your car to the top of a 2000-foot mountain (charge for that is ~12 miles), etc. My point is that it's not really an indicator of how far you can go. It's not intended that you use it for that purpose, at least not without a LOT of caveats & interpretation of that number.
It is likely (probable) that under good conditions, you'll be able to do better than 242Wh/mi in the LEMR. So your actual range is likely much greater than the stated 256 miles in ideal conditions.
Maybe they'll change the scalar for you guys to 235Wh/mi (62000Wh/264mi), and that would give you a 264mi full charge. But that would be inconsistent with their prior treatment of rated range for the Model 3. And it would be a little weird to decouple adjustments to this number from changes in the pack capacity due to age. (Really this full charge number is the only way to determine how much energy is in your pack - but you have to know the scalar Wh/mi to figure it out...)
If they make it too good, it'll be like in my P3D+ - where I get a lot less than the rated range. It is quite common to get 300Wh/mi, so really the full charge should be "250mi" (75000Wh/300Wh/mi). But they leave the full range at ~310 miles.
Also note that the max charge (in miles) that you see will come down over time as the battery degrades (right now we have no idea how much degradation will occur).
