I thought there were 4 Model 3 electric motors on the semi, now I see mention of 3? Would seem making two, 2 motor axles the same would be better than a 2 motor and a different 1 motor axle. What is right?
Better how? It would cost and weigh more and likely be less efficient. How would that be better?Would seem making two, 2 motor axles the same would be better than a 2 motor and a different 1 motor axle.
It would be interesting to know if those 3 motors are induction or permanent magnet motors, or a combination of those.The axle housings seem to be the same front axle has 2 motors rear axle has 1, as to why they removed one…..economics, weight, unnecessary, I’m sure that a company full of engineers and more educated about the project are probably doing what’s best for the product they designed.
I expect the opposite. The single motor will be PM for cruising, and the dual motors will be induction so they can free-wheel when not needed.I think that the two-motor axial use permanent magnet motors and the axial with a single motor uses an induction motor.
So the single axial might be only used to improve acceleration or regenerate braking, or on wet road,
but is shutdown when cruising to improve consumption..
Your breakdown Certainly has merit and sounds like an excellent way to design the system efficiency is key to this beastIt would be interesting to know if those 3 motors are induction or permanent magnet motors, or a combination of those.
My though was to be like the Model S Plaid with two PM for propulsion and a single induction motor for extra boost.I expect the opposite. The single motor will be PM for cruising, and the dual motors will be induction so they can free-wheel when not needed.
Great point. The combo is probably why they reduced the number of motors from four to three. They determined they only needed one of one type of motor to get the performance they need.It would be interesting to know if those 3 motors are induction or permanent magnet motors, or a combination of those.
What about 98% 99% and 100%The model 3 pm motor is rated at 97% efficiency I don't think you can get any more efficient than that
Not possible your going lose some thru heatWhat about 98% 99% and 100%
impossible like spinning one at 18K rpm you know like the plaid motors?Not possible your going lose some thru heat
Hmmm they specifically said PLAID motorsThe top of the chart said 97% . Same model 3 hardware..that’s such a game changer to have car and truck hardware the same for serviceability and stocking parts
"Stocking" parts? You ever needed service to replace something?!The top of the chart said 97% . Same model 3 hardware..that’s such a game changer to have car and truck hardware the same for serviceability and stocking parts
Probably not cost effective but there are now three plaid motors vs four Model 3 motors. One less motor but a similar performance might make it worth it. Not from the few hundred lbs of weight savings, but one less motor and inverter to breakdown. Overall reliability is improved assuming that the Plaid motor/inverter is as reliable as the 3.I'm surprised that the plaid motors are cost effective compared with model 3 motors. Clearly they don't cost as much more as one might guess (or at least in the context of the rest of the Semi's costs).
