1. If I buy a 3-pin IEC 60309 adaptor and fit a matching £30.00 "Commando" socket in my Garage why did I spend £400 on a smart charger.
Been using the Tesla 3 pin to charge a Zoe for the last few weeks.Hi,
Can anyone tell me if the 3 pin plug charging cable also works on non tesla EVs? Heading to the caravan with my partner. She has the Enyaq but wasn't provided a 3 pin cable. So I was hoping my cable might sort is both out?
They say that. But then they also say not to use an extension lead and I have used a 30m one with no issues so.....
Because, in England and Wales, if you have the capability to charge your car outdoors when using the socket, then the commando socket needs to be compliant with the same regulations that apply to charge points/EVSE. As many charge points have compliance built in (O-PEN and 6mA DC protection), the difference in price and installation complexity between a dedicated charge point and a compliant commando socket is not huge plus you will not be using what many would view as an occasional/backup device as a long term charging solution.
The Commando Socket would be in the garage and would be a backup for when the SyncEV point fails.
Though it doesn't meet regs it's actually an identical safety risk to using a UMC with a 13amp plug ... which everyone does from time to time because that's what it's for! I also have a 32amp socket in the garage that can be used with the UMC at 7kW as a backup for my charge point. It's a great reassurance because once in a blue moon these fancy pants smart charge points do decide to play up!
The umc gen2 is actually pretty good wrt the Regs. If the umc and commando is inside or in an IP rated enclosure you would be better than the extension lead and plastic bag brigade (lowest standard). Just out of interest this safety bit is not just about car chargers. Its about any formally earthed metalwork outside which may get turned live if a fault occurs in the underground cable or in your home, so probably should cover lights and electric doors etc.
Finally, I also believe the main reason for the difference is DC protection and earthing as the car could wallop you with 400V DC coupled with a lot of current which I imagine isn't particularly healthy.
I don't think this is the issue the Regs are striving to fix. Although I don't actually think they are sure either! The regs appear to make reference to some 'Unicorn' solution which doesn't exist ....yet.
