30 amp dryer outlet
bethterry
59
13
Panama City, Florida
We are getting our first Tesla this month! We have a 30amp (240v) dryer outlet in our garage, that we had installed when we built the house a couple of years ago. It's never been used. I have ordered the Nema 14-30 adapter. Is this all I should need? Do I need to set anything on the car for the voltage/outlet or do I just plug in?
Sorry for the noob question, but I don't want to blow up the house or the car!!
dgstan
379
273
Campbell, CA
I have a ChargePoint plugged into a 14-30. I get about 17 mph charging, which is fine for me. To rewire would have cost several thousand dollars, because my panel is on the opposite side of the house.
LongRanger
1,308
1,186
Wales
Just for your own peace of mind - double-check the fuse rating on the circuit for your dryer, and if it looks a bit old/indifferent, replace the fuse - and also label the thing for what it’s used for in case anyone decides to play around nearby with home works etc.
SilverString
256
142
Bee Cave, Texas
After a year with my MS and installing a NEMA-14-50 outlet, then upgrading to the HPWC, I have come to the conclusion that my pre-existing 30 amp dryer outlet and the included mobile charger would have sufficed. Instead of charging for an hour or two while I sleep each night it would have charged two or three hours. Would I have noticed? The HPWC looks good though...
disturbed932
49
5
Huntsville, AR
Just got my Gen 3 unite installed this morning.
M3BlueGeorgia
1,321
1,041
Atlanta, GA
Switchout out just the Chargepoint for a 14-30 socket would increase that to around 22 mph, and that shouldn't require any rewiring.
M3BlueGeorgia
1,321
1,041
Atlanta, GA
True, but I used to have a plug-in Prius that my daughter now drives. She comes to visit once in a while, so I still need a J1772. I typically charge at work (anyone remember when we used go to work?).
OK, two options:
1) instead of hardwiring the Chargepoint, put it on a 14-30 plug, and plug that into the socket
2) Put in an A/B switch so that either the 14-30 socket has power or the Chargepoint has power.
or just continue with what you have. :)
