30 Gallon Aquatank 2
Discussion in 'Model X' started by ohmman, Jun 21, 2018.
  1. ohmman
    ohmman Maximum Plaid Member
    North Bay, CA
    Our camper has a 20 gallon fresh water tank. I purchased a 30 gallon Aquatank 2. Very lightweight, but reviews and online anecdotes suggest it has good longevity and is tough. Dimensions are 36" x 36" x 14" which makes it a very easy fit in the back of the X. When empty, it rolls up nicely.
    I think the 60 gallon would work (36" x 48" footprint), but that's about 500 lbs of water in the back of the X. If I'm towing while carrying a full tank of water, that already maximizes rated tongue weight. This setup is 250 lbs and is more manageable.
  2. outdoors
    outdoors Always roaming
    off grid till Xmas
    Very nice. While boon-docking fresh water is often my biggest problem. I have often contemplated in removing black water tank and going full composting toilet for more fresh water. This looks a much better solution. Still might do composting toilet.
  3. ohmman
    North Bay, CA
    Yeah, my thinking is that I can make a run or two to potable water as needed, then return and fill the trailer tank. My inlet is lower than the X ride height so I should be able to gravity feed. Plus, I can push on this bladder and squeeze to start the siphon.
