No problem at all. I enjoy playing around with this.
Thanks again
At 61.7 mph range is same as rated range. So you can use that as a guide.
In that case it seems like 55kWh is a bit low again.
He's not saying there is zero contribution, but that it is not that significant anymore. From the Roadster efficiency excel file, rolling resistance makes up 16% of overall energy consumption at 80mph, while the break even point between aero and rolling resistance is somewhere around 42-44mph.That would have been true if the tires didn't touch the road. The weight of the car presses the car down to the road. The tires grip the road. This is something you want because otherwise you couldn't control the car. For example trains have very little rolling friction because they are on rails and don't need to grip. But if you put a train on a road, it would be like sliding on ice because it wouldn't grip.
Maybe you should do a calculation for the Roadster using Tesla's data file, to see if it matches up, to check on your assumptions:Let me show you my calculation with this data:
Weight= 1750 kg
Gravity= 9.81 m/s^2
Road friction coefficient for Model 3= 0.0153
constants to convert mph to m/s= 0.44704
air density= 1.2 kg/m^3 at sea level
frontal area=2.05 m^2
drag coefficient= 0.24
speed= 80mph
^2 means squared
Rolling Resistance Consumption = 1750 kg * 9.81 * 0.0153 * 0.447040 = 117.4 Wh/mi
Air Resistance Consumption = 0.44704*0.5*1.2*0.24*2.05*(80*0.44704)^2= 168.8 Wh/mi
Total consumption= 286.2 Wh/mi
Rolling Resistance Consumption is 117.4/286.2= 41.02% of total consumption. Rolling resistance consumption is independent of speed. It is the same at 1 mph or 100 mph. I will add more data.
Model 3 & ratsbew and other Model 3 fans,
You can now enter all Model 3 numbers on the sheet and see the range calculation. The file is here. Green cells are editable.
By using a higher weight number you get an even bigger discrepancy for rolling resistance. Again, I used the 2690lb number which was the quoted number for a 2008-2009 Roadster; keep in mind that JB's blog article came out in 2008 so you can't use 2015 numbers.I had a look at JB's excel file. It is different than what I use. It divides consumption into more categories and his air resistance is less than mine, but at the end the totals are similar. The formulas I use are well known physics equations.
For Roadster the data and the calculation would be like this:
Weight= 1335kg car + 82kg driver = 1417kg (82kg driver is from JB's blog here where he attached the excel file. Also source for car=1335kg)
Gravity= 9.81 m/s^2
Road friction coefficient for Roadster= 0.0153
frontal area= 2.086 m^2 source
drag coefficient= 0.35 source
speed= 80mph
Rolling Resistance Consumption = 1417 kg * 9.81 * 0.0153 * 0.447040 = 95.08 Wh/mi
Air Resistance Consumption = 0.44704*0.5*1.2*0.35*2.086*(80*0.44704)^2= 250.47 Wh/mi
Total: 345.55 Wh. JB's number is 361 Wh. It is a little different. He uses a different method. I'm sure for the Roadster his version is more accurate.
wallet said "weight shouldn't factor into it very much (if at all)". His comment is more accurate for the Roadster. Only 95 Wh/mi of 345 is from rolling resistance according to the same formula I use for Model S. However this is because the Roadster has a much worse 0.35 air drag coefficient because all the air intakes. Therefore I don't see any inconsistency here...
you may well want to check the different constants you are using to make sure they are correct.
You can now enter all Model 3 numbers on the sheet and see the range calculation. Open the file here and switch to page "Range Calculator". Green cells are editable.
Thank you once more
Ps: would not TM3 come with smaller wheels then 19"?
Well the way I see it is that, currently a range upgrade of 70Kwh battery is offered to Roadster. I'm pretty sure Model 3 would easily fit that battery pack if not even more. Considering the car is at least 3 years away from production, the battery pack size and storage density can be improved till the release date. so 300+ mile is a possibility. But do not expect the base edition to have it. The only question mark for me would be, if Tesla would want such a range on model 3 to compete with Model S sales.
I think it comes from the German automakers limiting their lower end models. For example M5 tends to be faster than the M3 and E63 faster than C63. Tesla however, doesn't necessarily have to follow that convention.I am not sure why this agrument keeps coming up.... Why does the Model S need to be superior in every way to the Model 3 ? They are completely different cars with different purposes. Is the BMW 3/4 Series slower the the 5 or 7 ? Different cars for different purposes with different specs.
Absolutely they would.The only question mark for me would be, if Tesla would want such a range on model 3 to compete with Model S sales.
I believe that may be do with the generation discrepancy. The F10 M5 is quoted officially at 4.2 (Motor Trend got 3.7) and I believe the E90 M3 is quoted at at 4.7 (Motor Trend got 4.2 for coupe). The F80 M3 is quoted at 3.9 /4.1 (Motor Trend got 3.8), but I believe the F10 numbers are due for an update (2017 m5 is being planned).Really BMW says M3 is 0-60 in 3.9 and the M5 is 4.2 at least in the USA
M6 is 4.1 sec
