300-plus kW inverter for M3 -- implies MS equivalent performance
Discussion in 'Model 3' started by Rashomon, Jun 29, 2016.
Tags:
  1. Rashomon
    Rashomon Member
    East Troy, WI
    • Informative x 3
  2. FirstSea
    FirstSea Member
    United States
    "If we can make the inverter just half a percent more efficient, that’s half a percent less battery pack that we have to put in the car or half a percent more range that the customer gets..."
    If true, the small size of the basic battery is beginning to make sense now; a bigger battery could easily push over 300 miles.
  3. Adrien
    Adrien Member
    Huntington Beach
  4. Evbwcaer
    Evbwcaer Member
    Minnesota
    Can somebody smarter than me fill me in as to why you would not have a DC motor for one of the motors in a dual motor?
    That way you can have a smaller, cheaper inverter and not use an inveter at all under low power demand conditions.....most conditions.
  5. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    I think for one Tesla wants to keep rare Earth metals used to a minimum. So you don't want to have large permanent magnets in a DC motor.
    It, also, might make it more difficult to synchronize the two motors, not to mention just making things more complicated.
    And finally the company is named Tesla which is a reference to the AC design used.
    • Informative x 2
  6. juanmedina
    juanmedina Member
    Greenville, SC
    Great news. The definition of ludicrous is "so foolish, unreasonable, or out of place as to be amusing; ridiculous" IMO since the M3 is going to have ludicrous mode its 0-60 should be less than 4 seconds..... anything higher than that will not be considered ludicrous in my book
  7. gavine
    gavine Petrol Head turned EV Enthusiast
    Southern New Jersey
    DC motors have brushes...yuck. Also, they have lower RPM so you would need a transmission with gears. AC is the way to go.
  8. TEG
    TEG TMC Moderator
    • Informative x 3
  9. trils0n
    trils0n 2013 P85
    SF Bay Area
    Each type of electric motor has different characteristics (efficiency, cost, power density, control, etc). There are lots of different types of electric motors, and each make sense in different situations and applications. Tesla thinks the AC induction motor they use makes the most sense for their cars. It is efficient, allows very precise and accurate control, contains no rare earth permanent magnets, maintenance free, etc.
    • Like x 4
    • Informative x 2
  10. garsh
    garsh Re Member
    Pittsburgh
    • Informative x 4
  11. SageBrush
    SageBrush 2018: Drain the Sewer
    Colorado
  12. zenmaster
    zenmaster Member
    Atlanta
    insane: < 4s, ludicrous: < 3s.
  13. trils0n
    trils0n 2013 P85
    SF Bay Area
    300kW = ~402hp. Pretty close to my P85 (advertised as 416hp). Does 0-60 in 3.9-4.2 secs depending if I can get traction. Smaller, lighter Model 3 with same/similar power sounds wonderful.
  14. Garlan Garner
    Garlan Garner Well-Known Member
    Chicagoland
    I agree. I'm looking for 0-16 to be sub 3seconds.
  15. Garlan Garner
    Chicagoland
    Yes, Yes, Yes!!!!!!!
  16. Garlan Garner
    Chicagoland
    It sure does.
    This thread is Ludicrously good. I can't wait.
  17. zenmaster
    zenmaster Member
    Atlanta
    Was hoping for 1 hp for every 9lbs or better.
  18. ModelNforNerd
    ModelNforNerd Active Member
    Ayer, MA
    Someone more familiar correct me if I am wrong, but aren't these specs just for the rear motor?
    the HP/weight ratio might very well get to your 9lbs/lb-ft in AWD.
  19. juanmedina
    juanmedina Member
    Greenville, SC
    100% agree.
    Now baby Jesus please don't let the M3 PXXL be more than $60k :D
  20. wallet.dat
    wallet.dat Member
    SW
    I'd love for this to be a standard SLA, but I don't think the ModX achieves this.
