juanmedina
I'd love for this to be a standard SLA, but I don't think the ModX achieves this.
Yeah but 3.2 seconds 0-60 for 5000lbs SUV is ludicrous
I take this to mean that the power invertor will not be a limitation to performance.
Can one really infer performance based on the invertor specs? Over 300kw invertor still needs a battery that will feed it that much power, and also the motor size must mean something.
I'm not smarter than you. However, I can assure you that AC motors, which are for all intents and purposes the same as "brushless DC" or electronically commutated motors, are much much more efficient than brushed (mechanically commutated) motors. Three-phase AC motors (like the ones Tesla uses) can achieve 98%+ efficiency, whereas brushed DC motors get stuck in the 70-90% range. And brushes wear out, so you would have to replace the brushes after a certain number of km, just like you'd have to change your engine oil. Today's semiconductor tech allows for inverters to be at least 90% efficient, probably closer to 95%.Can somebody smarter than me fill me in as to why you would not have a DC motor for one of the motors in a dual motor?
That way you can have a smaller, cheaper inverter and not use an inveter at all under low power demand conditions.....most conditions.
Since the new inverter is based on something made ad-hoc making different inverter-version could be easily done.Yes that will be true if it is indeed a 300kW inverter. But Tesla is optimizing the Model 3 for manufacturablity and cost. Putting an overly large inverter in the vehicle if (any of its trim levels') battery cannot support it, or it's motor cannot accept that level of power seems wasteful.
Plus it is basically the only clue we have (besides 0-60 target in base version), so wild speculation must occur.
Someone more familiar correct me if I am wrong, but aren't these specs just for the rear motor?
the HP/weight ratio might very well get to your 9lbs/lb-ft in AWD.
100% agree.
Now baby Jesus please don't let the M3 PXXL be more than $60k
There's no way around the Model S having more mass. If you don't artificially limit the motor size or battery output then the Model 3 should always be able to out accelerate a Model S.Implies even faster than Model S performance in my opinion...
But the 3 probably will have smaller battery pack ( it's just a question of how much space you can have ) so, overall, the S would allways be faster since it can deliver more amp
Well.... the price ratios from the bottom end S, to the bottom end P90D, to the top end is P90DL are 166% and 216% respectively. if you have the same thing with the 3, that should imply a are bones PXXD M3 for 60-ish and the top end at around 75-80.
I keep negotiating my "must haves" in my mind... I think this is my list for now:If Tesla offers 3-ish seconds 0-60 for $65k or less I'll be in heaven
One of the engineers mentioned a 20% weight reduction and that makes it nearly 1000 lbs lighter.Model 3 will be 1000 pounds lighter than S. I know many on here doubt that. I would be glad to make a wager
1. Ultra White Seats ( $2,500 ?)
2. High Fidelity Sound System ($2,500 ?)
3. Autopilot Activated ( $ 1,500 ? )
4. Supercharging Activated ( $ 1,500? )
5. Performance Upgrade (this is the biggest variable on what this will cost to get near 3 second 0-60 ) $ ??????
I'm actually hoping to accomplish all this for around 15k in upgrades... which after tax credit would bring my final cost down to $43,000 ish...
They've found a balance between power/capacity in the cell, so for now this is a constant.A smaller battery pack will translate into less energy, but not necessarily less power while (close to) fully charged. So if Tesla want to, they can create a Model 3 with a Model S acceleration.
