Hi All,
I have the 32A 3phase charger sitting in a box ready to install (was given to me). I am not running three phase to it (way too hard due to fuse box location). I do however have a single phase 240V 20A socket in the garage that was put there for welders etc which I want to use.
Looking over the installation manual it looks like this charger can run on single phase no problem, however there is some wording that isn't very clear to me. Under Single Phase without neutral....
"For installations without a neutral and 230V from line to line, connect any two lines (L1, L2, or L3 in the illustration) to the L1 and neutral positions on the Wall Connector terminal block".
I read that as connect L2 and L3 to L1, in other words connect all three phase inputs together if only single phase is available. The diagram does not show that by the way.
Thanks.
Thanks.
