4 month storage question
Discussion in 'Model S: Battery & Charging' started by mdlambert, May 7, 2015.
  1. mdlambert
    mdlambert Member
    naples florida
    I am about to leave my winter home for about 4 months. I'm not sure what I should do about charging my P85D. Leave it plugged in at a percentage charge? Don't leave it plugged in? Change a setting ?
    Please advise
  2. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    If leaving it plugged in is an option, then by all means leave it plugged in and set the charge level to the lowest (50%) setting. A shame to leave it...why not take it home with you...or drive it home?
  3. Kalud
    Kalud Active Member
    Montreal, QC
  4. mdlambert
    mdlambert Member
    naples florida
    Thanks for the notes
  5. Cottonwood
    Colorado
    #5 Cottonwood, May 7, 2015
    I would leave it plugged in with the charge threshold set at 50% as others have said.
    In addition, make sure that you can access the car from a phone app, Visible Tesla, etc to verify that charging is still happening. With the App and notifications on, you will see that the Vampire is being fed every few days which is a good reassurance that all is well. If for some reason the charging stops, then the Vampire will drain the battery. If you can leave a key and access with someone there, they can restart charging (unplug and replug is usually all that is needed) or take other measures to get charging started again.
    To minimize the Vampire drain, in Settings, under "Display", turn "energy savings" on, and uncheck "always connected."
  6. Patrick W
    Patrick W Active Member
    SLC, UT
    Very helpful thread. I just picked up my S last week and was not sure about what would happen if I have the car for a couple of days where I can not charge. If I'm understanding the above correctly it is ok to stay unplugged for even several days provided the battery has lots of charge to start. Y'all please correct me on my understanding if Ive got that wrong.
  7. efusco
    Sure, a few days, even a week or so is OK. In a pinch you could likely go several weeks if the car is set up properly to minimize vampire drain. But, ideally, you want to plug in daily.
  8. rickgt
    rickgt Enthusiast owner/member
    Carmel
    be careful about the always connected part... If you do that, it will be hard to check on the car from the app
  9. efusco
    Not true, you can still wake it up via the app.
  10. jmhays
    jmhays Member
    Minneapolis
    Not to worry, just leave me the keys and I will GLADLY charge it for you every single night. I will also drive it during the day just to make sure the charging station works as expected. I won't even charge you for the service :)
  11. ReddyLeaf
    ReddyLeaf Active Member
    WA State
    I'll second the offer and keep it between 40-60% SOC for the best battery life.:cool:[video]https://youtu.be/ugGyoGtPMbA[/video]
  12. Park2670
    Park2670 Member
    Utah
    I have an unused 14-50 in my garage if you want to keep your car there charged. Ill make sure it stays clean and pretty. I am just on the other side of the mountain.
