40 amp Charging 2013 p85 25 mph normal?
Discussion in 'Model S: Battery & Charging' started by GadgetGeek407, Dec 7, 2016.
  1. GadgetGeek407
    GadgetGeek407 Member
    Orlando, FL
    I read it should charge at 29 mph but is doing between 24-25 and going between 39--40 amp ...is this normal
  2. MikeC
    MikeC Active Member
    Los Angeles
    What's the voltage? The rate should be 29 at 240V/40A.
  3. tga
    tga Supporting Member
    New Hampshire
    I'm going to guess you're charging on a commercial 3-phase system (208V). 25/29 * 240V = 207V.
    24-25mph @ 208V is pretty reasonable.
  4. Rocky_H
    Rocky_H Active Member
    Boise, ID
    How fast miles go into the battery is based on power (watts or kilowatts). That is voltage times current, so either of those being lower will make the charging rate be lower. Residential electricity usually has 120V and 240V, but commercial properties usually have 120V and 208V. 25 mph is about what I have seen from the 208V systems.
  5. kort677
    kort677 Banned
    florida.
    25 MPH is on the lower side of normal, I usually get 28-29 MPH
  6. GadgetGeek407
    Orlando, FL
    I do have this at my office warehouse so I'm assuming based on the comments I've seen is cause it's not residential?
  7. brkaus
    brkaus Well-Known Member
    Austin, TX
    You need to look at the voltage that is displayed when charging. If around 208, then yes.
  8. GadgetGeek407
    Orlando, FL
    Ill check tomorrow, if thats the case, is there a way to speed it up or not really?
  9. tga
    New Hampshire
    Short of installing a higher amperage circuit/upgraded charging station, no.
  10. auger
    auger Member
    SoFL
    Is another 4 mph important?
  11. scaesare
    scaesare Well-Known Member
    NoVA
    This.
    I have 208 in the parking garage here at work, and I get ~24-25 MPH of charge.
  12. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    As others have noted, check to see the voltage the car displays while charging. Is there anyone at your work location (landlord?) who can tell you the voltage/amps of the outlet you are using to charge?
    You can't readily change the voltage the outlet provides but if you can verify the voltage at least you have an explanation for the slightly lower charge rate than what you were expecting it to be.
  13. ColdRauv
    ColdRauv Member
    Minnesota
    If you must, you could look into installing a 1.5 kVa buck-boost autotransformer between the panel and the receptacle to raise the output voltage from 208 VAC to 240 VAC. You would need to verify the existing conductors and circuit breaker first (probably OK, though). Not worth the time and money spent for just a few more MPH charging speed.
