eprosenx
Hmmm. Skipping the "outside" part for a moment, it bears pointing out that everything related to "disconnecting means" (readily accessible, locked open) seems to be solved with a receptacle and plug.
I bring this up due to all the discussion of the downsides of adding a pigtail to the HPWC, and how scary that can be. This is *not* a recommendation, merely a mention.
The plug is going to be right there, readily accessible. And once it is unplugged, it isn't going to accidentally plug itself back in. An additional benefit is that everybody knows how and where to break the circuit if needed.
(for the record, I'm using a NEMA 14-50p on my HPWC, and my 14-50R is on a breaker that's a a foot away from the HPWC. And did I mention my 8 gauge, non-Romex, properly temp-rated, up-to-code wire for the 50A circuit?
So I also found last night in my newly discovered 2017 NEC 625 the following:
NEC 625.44 (C) - "Fixed Equipment - All other equipment shall be permanently wired and fixed in place to the supporting surface."
My reading of the code is that a "wall connector" counts as fixed equipment. It is certainly not "Portable Equipment", and I do not believe it can be considered "Stationary Equipment" (which can have a plug) since it requires tools to remove it and move it around.
So my apologies for being pedantic, but I believe that what you have described is not code compliant if it was installed today. (I absolutely believe what you have done is likely safe, but I just document this here for other folks that may stumble upon it later in searches) There are also extreme limits in NEC 625 around the length of pigtails where allowed. Like 12 inches as specified in NEC 625.17 (A) (3).
Over 20 years ago, every EV charger (yes, these were chargers and not EVSEs) was "required" to be hard-wired. And for the past 20+ years, I've plugged in my chargers (and now EVSEs). Call me crazy, but I can't be without the flexibility that this provides. I have three 14-50R's in my garage, and being able to reconfigure my parking and charging instantly has proven to be worth it's weight in gold over the years, and many cars. The only downside for me is that I'm limited to a 50A circuit. But considering that every EV I've owned before the Tesla topped out at about 17 mph charge rate, I'm OK with the 37 mph of the Model 3 on a 50A circuit!
Yeah, makes sense to me! I take it you have multiple plugs on the same circuit? Or are they all on different circuits?
Under the 2017 code you can't have more than one receptacle per circuit if they are intended for vehicle charging.
Thanks for all your insight btw!
