400 volt to 12 volt converter?
Discussion in 'Roadster 2008-2012' started by Pantera Dude, Nov 14, 2013.
Tags:
  1. Pantera Dude
    Pantera Dude Member
    Long Beach, California
    I don't remember what the box with the fins on it and the heavy orange wire running to it, under the front hood/bonnet does. It appears it is the high voltage to 12 volt converter, is that correct? My car is a 1.5.
  2. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    I am told it is a voltage converter for the HVAC.
  3. Pantera Dude
    Pantera Dude Member
    I'll buy that!:biggrin: I wonder why so much heat is given off during the conversion to require fins for cooling? Does the converter take care of all the car's 12 volt needs? Is the converter the same as a transformer? Anyone, anyone, Bueller?
  4. strider
    strider Active Member
    NE Oklahoma
    Yes. Transformers change voltage, rectifiers convert AC into DC, and inverters convert DC into AC.
  5. hcsharp
    hcsharp Active Member
    Vermont
    No. A transformer only works with AC. A DC-DC converter takes high-voltage DC and converts it to a different DC voltage (in this case ~12v). Sometimes they convert the incoming DC current to AC with an inverter so they can use a transformer to change the voltage to a different AC voltage, and then rectify the output back to DC.
  6. markwj
    Hong Kong
    Rectifier: AC->DC
    Converter: DC->DC
    Inverter: DC->AC
    Transformer: AC->AC
    As an aside, the DC voltage from the pack to that converter was explained to me as -200V to 0V and 0V to +200V (so a 400V difference).
  7. Pantera Dude
    Pantera Dude Member
    "As an aside, the DC voltage from the pack to that converter was explained to me as -200V to 0V and 0V to +200V (so a 400V difference).[/QUOTE]"
    Does that make sense? I would think the converter would reduce the full 375 volts to 12 volts? I am NOT an electronics guy.:biggrin: And again, why would so much heat be given off in the process?
