I have no reason to believe PGE likes me. We shall find out soon. Up to 22.02kw. Will I hit the max of 22.8? An hour to goLol and PG&E hates me but likes you?
Sunrun stupidly went through PG&E's planning department... if we had just pulled the meter socket and installed my system it would have taken like 2 days instead of 180.
That's not quite right, assuming by orientation you mean azimuth (so the panels point towards the equator).If there was no issue with orientation or shading, everyone would max out at 1 pm on June 20.
YES, shade, I have lots from neighbors trees, and some from my home structure. I have a lot pointing north, which maybe okay now, but nothing in the winter. this is why I am trying to over kill stuff. I have plenty of batteries. Just need enough solar to charge as much as possible, and send as much to PGE NEM2 for winter use when I will have to pull from the grid.Your experience, and mine, illustrates why orientation and shading is such a big factor. If there was no issue with orientation or shading, everyone would max out at 1 pm on June 20.
In my case, max production seems like it might have been in late May or maybe late July coming up, as my set up is 35 panels facing mostly south on a 20% roof vs. 13 facing mostly north. on a 20% roof.
The closer the sun gets the more the north 13 come in to play, but there seems to be a slight loss, due to roof angle for the south 35.
ICF Submitted: 5/20/2021
Request for 7 day discharge data: 5/24/2021
Homeowner Requested Report from Tesla: 5/24/2021
Tesla Replied with Report: 6/2/2021
Report sent back to SGIP for ICF review 6/2/2021
Revised ICF Received: x/x/2021
ICF Inspection: 6/23/2021 scheduled
ICF Approval: x/x/2021
Just got the email
TRC Energy Services, and we conduct Self-Generation Incentive Program (SGIP) rebate inspections on behalf of PG&E on the 23rd. So, guess moving along, even though have not received anything back on the ICF
Not to be that guy, but the start of the sentence is "if there was no issue with orientation or shading...." which is exactly what you elaborated on, so the sentence is not only right but exactly right! Ha!That's not quite right, assuming by orientation you mean azimuth (so the panels point towards the equator).
At solar noon on the summer solstice, the sun's elevation angle in the sky is your latitude plus 23.5 degrees (the angle of the tilt of Earth's axis relative to the place of its orbit). So that's only optimal if your panels are at that elevation angle. Roof mount panels are usually at the roof elevation angle, so the day of the year when the sun's elevation angle is optimal will vary with roof slope. On a ground mount array, you could set it to the optimal solstice angle, but that would only make sense if you were changing the angle every month or so. If you wanted to choose one elevation angle to maximize production for the full year, you wouldn't pick the extremal elevation angle.
Cheers, Wayne
No problem, that's why I prefaced my remarks with "assuming by orientation you mean azimuth". : - )
Depends on what you are optimizing for. The simplest case would be flat horizons all around, no atmospheric effects (on the Moon), no shading, just optimize for total kWhs per year. Then there's a well-defined optimum, the azimuth is always towards the equator, and the elevation angle depends on latitude only.So, a question, does it follow that there is no "ideal" orientation? Or would it be based on latitude? I guess this only matters if you have the option to install at a selected angle.
If you want to optimize kWhs per year, and you don't have time of day weather effects or E/W horizon effects, then all south. Given any of those effects, or a TOU rate schedule and optimizing for $s, there will be a single optimal azimuth which may differ from due south.Or, here is another question I don't think I have seen, if a person's roof allowed, is it better to install all south facing, or some east, some south and some west?
Assuming, let's say, a 20 degree roof angle in SoCal.
I think I have a slight horizon effect where east has some hills not in the west, but mostly it is that (1) what seems to happen with the south array is that their production does not increase as the sun moves towards the summer solstice, and (2) the house is not directly N/S, its more NW/SE. As a result of that, as we move towards the summer solstice the north array indeed comes more "into play" but its basically balanced out by the 35 panels in the south array becoming a bit less "in play." Its really obvious these days right before sunset. As the roof ridge which acts as the dividing line between then north array and the souht array does not face pure E/W, the south 35 panels are completely shaded that last half hour of sun, not that there are a lot of kwh available in the last half hour, but still.No problem, that's why I prefaced my remarks with "assuming by orientation you mean azimuth". : - )
But as I pointed out, if you pick one optimal orientation for the year, you don't expect the maximum production on the solstice (ignoring temperature effects), since that's an extremum of the solar conditions over which you need to optimize.
Cheers, Wayne
I just put them all where they fit on the roof. Some that are not "perfect" is better than nothing.No problem, that's why I prefaced my remarks with "assuming by orientation you mean azimuth". : - )
Cheers, Wayne
I think you also need to take into account what part of the day you already consume the most power, and how easily you can change your usage.Not to be that guy, but the start of the sentence is "if there was no issue with orientation or shading...." which is exactly what you elaborated on, so the sentence is not only right but exactly right! Ha!
Well, hope that came through with the humor as intended, because if there is anyone on here who adds value its mr. wwhitney.
