ElectricTundra
P85D AP1
Do you need a full-size ground? It use to be that with straight 240v (no neutral) that you only needed a 12g ground.
Digging up this thread from the dead!
Would this cable be acceptable for an 14-50 extension cable? It's not SOOW, but looks exactly the same. It says it is "indoor" cable, but if I am gentle with the cable, would it be okay for occasional use? I plan to use it when visiting a couple locations with hard to reach 14-50 receptacles.
http://www.lowes.com/pd_294914-295-63950032_1z0yt31__?productId=50188983&Ns=p_product_price|1&pl=1
I'm going to be going to a vacation house with unknown power situation soon. I picked up a 14-50 to 14-30 and 14-50 to 10-30 adapter. When I get there, if I need an extension cord, I'm going to get it delivered right there with Amazon Prime:
Amazon.com: Camco 55195 50 AMP 30 Extension Cord with PowerGrip Handle: Automotive
Basically I don't see that I should buy it until I need it.
You don't really need a 14-50 to 14-30 adapter. You can just use a hack saw to "modify" the neutral prong of the male end of the 14-50 extension cord. Then it will fit a 14-50 or 14-30 receptacle (obviously you have to dial down the amperage accordingly), and even plug the modified end into the 14-50 to 10-30 adapter for a 10-30 receptacle.
I bought a 50' extension cord...want to always be prepared for a long stretch to a receptacle.
That's NM cable, or "Romex", intended for use as infrastructure wiring. It's some pretty stiff stuff and rather hard to manage for portable means. Overuse can result in the wire breaking strands from bending/manipulating it too much.
According to Code, it's not acceptable to use extension cords in any case because Tesla's instructions forbid it (NEC 110.3), so from a legal/insurance/liability standpoint, it doesn't really matter what you use.
Will it work? Yes. Will it be safe? The first few times, but if you begin to use it regularly, especially bending and twisting it, it can begin to break the strands in the cable. Is it legal? Not at all.
If you think you require an extension cord, it's best to source the rubber jacketed cord.
Moving to a house where the outlet is on the opposite side of the garage that I want.
I second that. Move the outlet. Shouldn't cost all that much, especially if you don't mind conduit mounted on the wall (it's a garage, that kind of thing just makes it look more manly...yeah, that's it...)In a case like that, I would pay to add a second 14-50, move the original one, or put in a switch box and a new 14-50 (the switch box would activate only one 14-50 at a time to meet code).
Using a 50 Amp extension cord occasionally on trips is one thing. Using it permanently at home is a bad idea.
Yes, they can. Buy why don't you just park on that side and use the outlet where it is? The UMC should reach.Thanks. I'm leasing the house so I'll ask. They already installed it on the left garage wall and put the outlet in. If the wire is already terminated at the outlet would they be able to reconnect what's already then to a second wire and run it along a metal tunnel along garage wall?
If you are going to drive anywhere away from Superchargers and do not have a CHAdeMO adapter, I recommend buying the Camco 55195 50 AMP 30 foot Extension Cord.
