500 days of (not) charging
Discussion in 'Model S: Battery & Charging' started by Missile Toad, Feb 6, 2018.
  1. Missile Toad
    Missile Toad Member
    Houston
    tl;dr;
    ...........in
    Today......5 years..Type
    6%.........7%.......Critical Charges, Usually a Supercharger, but can be an overnight WC
    1.0%.......7.0%.....Opportunistic, building extra cushion, meals, shopping, out on the town
    87%........80%......Routine, daily charge habit @ home, work, school, or hotel charging on an extended stay
    4%.........2%.......Trials: making sure my equipment works & the Wall Connector (or other non-Supercharger)
    8%.........8%.......No charging at all (will be higher in retirement or vacation by jet)
    I have had my S 70D for about 500 days now, and I've built up some rough statistics. I'm 52 years old in semi-retirement. My wife and I have a SUV ICE that competes with the S 70D for road-trips. I've broken down my charge habit into five categories, where one is the car just sitting idle (about 1 day or more per week). I've been trying to figure out how often I rely on chargers other than Supercharging. In my 'newbee' year, I made a lot of trials of nearby chargers, mainly to confirm a) they worked; b) they worked on a taper; c) and my car equipment worked. That phase is diminishing now.
    All data is a percentage of all charging events. In other words I vacation/road-trip 3% of the 500 days, but needed multiple charges each of those days to complete my trips. The destination charger network is not as robust here, in Texas, as it is in California -- but Texas grows more like California every month (Wind generation is making our grid greener). Having said that, I expect, in 5 years, there will be double the Supercharger site count (in Texas), and maybe 4-5X more destination charging options (not counting non Wall Connectors). I am a home-owner, and so, it is trivial to charge at home, unlike apartment dwellers. The Critical category is the sort of charging where you simply will not make it to your destination without an unplanned lengthy stay -- inconvenient to the driver and others if that charge should fall through.
    I wonder how everyone else's situation compares? Do others think they will grab more charges outside their home/work/school environment, as I think that I will? Or do people think that there will be such a surplus of drivers that it becomes difficult to squeeze in to limited WC/Supercharger stalls, say, in 5 years?
  2. scottm
    scottm Version 9 software sufferer
    Canada
    Curious what kind of job / career you're retiring from?
    I make it a game to never charge at home, if possible.
    It's getting easier and easier... to find meaningful sources convenient to what I'm doing. Call this opportunistic. I plug in, if only for 10 minutes for a quick visit to a shop. Or all afternoon and use that spot as my home base for walking around in an area.
    I am still almost never seeing competing forces at places where I charge... 2nd stall remains empty... so I don't feel bad about this.
    Often parking with 70%+ in the garage overnight. I probably bring enough power home to power the house on most days if the car could reverse feed the house.
    ..obviously the need to charge arises from your needed or desired use of the car. If you see a rise in this category, you need to get out more!
    Cheers
  3. Missile Toad
    Missile Toad Member
    Houston
    Update at ~ 18 months
    ...........in
    6%..................Critical Charges, Usually at Supercharger, but can be an overnight WC
    1.0%................Opportunistic, building extra cushion, meals, shopping, out on the town
    35%.................Routine, daily charge habit @ home, work, school, or hotel charging on an extended stay
    1%..................Trials: making sure my equipment works & the Wall Connector (or other non-Supercharger)
    60%.................No charging at all
    Car is plugged-in to NEMA 5-20 @ 12A x 115v nearly every night. I'm deliberately not charging on nights when wind generation is low on the grid... so that explains the large 'no-charge' category. I am now retired (though persistently writing (mangling) code). Importantly, I have access to a 70+ Amp Wall Connector in the garage, which I seldom use (my wife has dibs on that). Even during full-time employment, I could easily pull off a 50%-of-the-time no need to charge overnight. After little more than 1 year of WC availability, I have found that 70A is overkill, and could easily serve our needs at 40A. As usual, your electrons may vary. Again, this is Texas, where wind generation is ample, but only at night -- so, fewest carbon atoms are harmed using this practice.
