I would think the Semi is the most likely platform for a 500kWh battery.
Or maybe the ride height of the S or X will increase by a foot or more to accommodate the enormous battery. Gonna need that ride hight auto-adjust thingy option for sure...
I think the fella was messing with you. If somebody can ever produce a Tesla-pack size 500 kwh battery, then we will be living in a very different world. Petroleum would be used for fueling ships, train locos and some aircraft, but nothing else.
It would make sense that this was talking about the different versions of P90D batteries. First gen was put out ~460kW or so, next was ~500-512kW. Perhaps it was as simple as that, 500kW battery, not 500kWh.
The oldest old, who appeared to be Eatern European in his late 50's says "is that your X out there?"
As I understand it, the diesel electric trains do have batteries. The diesel generator charges those batteries. The electric motors are driven from the batteries. I would hope that if they added regenerative brakes, those would also put energy in the batteries.At least on some routes we could see electric trains. Diesel locomotives now have electric motors and the diesel is used to run a generator. Today they run regenerative brakes, but they just run that energy through resistors and vent the heat out the top. If they had batteries, they could put that energy back into the batteries.
Good grief, I'm not sure why I'm even posting this as I'm sure I will get fah-lamed.
So, I'm having dinner tonight at a taqueria in Redwood City, and three guys in tesla jackets approach me.
The oldest old, who appeared to be Eastern European in his late 50's says "is that your X out there?"
"Yes," I say. "I worked on the battery in that", he says.
"Cool! Hey, is it true that there will be a 100kWh battery soon?"
"500." "500 miles?" "Kilowatt-hours" ""
"Roadster will get next gen first". Then my kids expire and I thank the gentleman and depart...
Anyway - the incident is 100% true. The guy for sure works for Tesla.
But the actual info - YMMV (pun intended).
That's usually quite easy actually, you can see it, but also hear it when they both speak EnglishHow does one distinguish an Eastern from a Western European?
You forget it makes perfect sense for the Semi.
I believe it was about something else - the Model X.
Even that would only be 250 kWh max. At 2.5 miles per kWh pessimistically, that's still 620+ miles.
I think the Semi has more then 500kWh. But for a big pickup or a smaller truck then the Semi it could make some sense.You forget it makes perfect sense for the Semi.
