50AMP Ext. Cord Management
Discussion in 'Model S: Battery & Charging' started by blee321, Sep 28, 2016.
  1. blee321
    blee321 Member
    Stony Brook NY
    I recently purchased a 50 foot NEMA 14-50 extension cord and its a beast to deal with when not in use... it sits in my driveway like a sore thumb.
    I am reaching out to the forum for advise on how to best store coil the massive cable.
    Thanks all in advance!
  2. AndreSF
    AndreSF Member
    San Francisco, CA
    Perhaps garden hose storage/management systems would work for this?
  3. timk225
    timk225 Active Member
    Pittsburgh
    How thick is the cable and how much does the whole 50 foot piece weigh?
  4. DarkMatter
    DarkMatter Member
    Olympia, WA
    You can use garden hose storage so long as you unroll it before use. To manually coil it lay it in a figure eight, like rope is stored on the decks of ships.
  5. AWDtsla
    AWDtsla Active Member
    NE
    That's why I built a cable that has no neutral wire and as made of rubber that stays flexible when it's cold. It's not much harder than a normal extension cord to handle, other than it's heavier.
  6. mknox
    mknox Well-Known Member
    Toronto, ON
    I bought one of those 50' beasts too! I have used it at a rental property I own (to get from the kitchen stove outlet down to the garage and out to the driveway) and at a friends summer lake house for the same purpose.
    Mine just stays coiled up at the bottom of my frunk (I have an older RWD car with the big frunk).
  7. whitecotton
    whitecotton Member
    Houston, Texas
    They make reels specifically for nema 15-40 cables
