I got battery replacement on my TM3 SR+MIC 2021 LFP in warranty due to isolation failures (waited 3 month for the battery to arrive). They confirmed I got a new battery, I can see in SMT that it has almost zero AC/DC Charge Total. I'm not sure if they manufactured a new 55 kWh battery for me (AFAIK 55 kWH LFP is not being used in new cars anymore) or gave me 60 kWh and software-locked it.
I have an old screenshot of ScanMyTesla showing "Nominal full pack" of 52.3 kWh and "Energy buffer" of 2.35 kWh. "Full Pack when new" was 55.1 kWh. With the replaced battery I saw "Nominal full pack" 55.0 kWh, "Energy buffer" 5.75 kWh, full pack when new same as before (55.1). After a week, nominal full pack is little lower (54.7), but energy buffer got higher, first about 5.8 kWh and today 6.00 kWh.
I have found in some other thread info that the Energy buffer indeed can change based on how BMS is confused. Do you think so big buffer is just result of new battery (with BMS still calibrating - I just full charged only maybe 5x since the replacement) or can be indication of bigger battery capacity?
How does software-locking capacity work? Do they limit max charge (so 100% is in fact maybe 95%), or max discharge (so 0% is in fact ~5%)?
I have the info from invoice ASY,HVBAT,E1 PRIS,RWD,3PH (1567439-00-A), but google nor EPC Tesla knows anything about it.
