- Aug 20, 2006
- 21,717
- 8,682
http://cgi.ebay.com/ebaymotors/2010...iewItem&pt=US_Cars_Trucks&hash=item1e5c62b387
This particular Roadster is complimented with a Sterling Silver exterior with Light Gray/Red Inserts Leather!
Original MSRP $121,600
Metallic Paint
Performance Tires
Adjustable Suspension
Electronic Group
Premium Interior
Above Are Paid Options
248-hp Electric Motor
Lithium-ion Battery Pack
Removable Soft-Top
Rear-Wheel Drive
Drivetrain:
Single speed fixed gear with electrically actuated parking lock mechanism and mechanical lubrication pump
Motor:
375 volt AC induction air-cooled electric motor with variable frequency drive.
Base: Output 288 peak horsepower (215kW) and 273 lb-ft (370 Nm) of torque. Redline at 14,000 rpm.
Sport: Output 288 peak horsepower (215kW) and 295 lb-ft (400 Nm) of torque. Redline at 14,000 rpm Chassis:
Resin-bonded and riveted extruded aluminum monocoque. Four-wheel independent suspension featuring upper and lower unequal length wishbones and co-axial coil spring telescopic dampers
Brakes:
Hydraulically operated. Tandem master cylinder with vacuum servo and anti-lock braking system.
Top Speed:
125 mph (electronically limited)
Range:
245 Miles
Expected Battery Life:
Seven Years Or 100K Miles
Full Charge:
About 3.5 hours using the Tesla Motors Home Connector at 240 Volts and 70 amps
Balance Of Bumper To Bumper Warranty 3yr Or 36K Miles
