6-20 Mobile Connector No lights
PLCR
New Member
Dec 27, 2020
4
Edmonton
Hello.
I've installed a 240v circuit in my garage, and I have power to both cables at the receptacle. However, when I plug in the mobile connector, there are no lights, yet when it's plugged into a 5-15 receptacle, I do have lights.
I'm wondering if I have made some simple mistake in the install?
I can't test the charge with the MY as it's currently in the shop having a heater sensor fitted (we only had it two days!).
Thanks in advance.
NickFie
532
588
Near Philadelphia, PA
Ensure breakers are on. There should be two breakers, one for each hot line to the socket. 6-20 does not have a neutral connection.
Double-check that you have 120 Volts from each of the horizontal sockets to ground (round socket).
Apologies if I seem to be treating you like an amateur. Just don’t know your skill level.
The one time I encountered a 6-20 receptacle - while stopping over at a distant friend’s house - I didn’t have the correct adapter. Like getting into the keg party and discovering it’s “bring your own cup night!”
MY-Y
934
997
MD
If you have ~240 volts between the blades, it should work. Check that voltage. (It should have a double (2 pole) breaker, or a pair of single breakers with a bar between them to ensure they turn on and off together.)
PLCR
New Member
Dec 27, 2020
4
Edmonton
No apologies needed, and thanks for the response. I've just checked with a multimeter and it's 120v to each side. The breaker is a double pole 20 amp.
I am very much an amateur, but thought this would be in my skill capacity! With power to the receptacle, I don't understand how there are no lights siding but there are when it's plugged into a regular socket.
I'm even wondering if it doesn't show lights until it's plugged into the car (but can't check until January 10th unfortunately).
PLCR
New Member
Dec 27, 2020
4
Edmonton
Thanks for the response. Double pole breakers installed, with just one receptacle on the circuit. 120v siding each side with the multimeter.
arnolddeleon
792
861
SF Bay Area
Not to be silly, but you did check you have 240V between the two hot wires? To rule out the very unlikely scenario the 2 hots are wired up to the same phase.
I'm betting this is the case. I'm guessing the OP used a twin/tandem breaker vs a proper two pole breaker.. A picture would be helpful.
Reactions: ratsbew
MY-Y
934
997
MD
I don't think that's silly; that's exactly what I was thinking as well. That's why I recommended checking to see if there is 240 volts between the blades.
Reactions: frankvb
PLCR
New Member
Dec 27, 2020
4
Edmonton
Thanks for the responses everyone! So I checked with the multimeter and I was reading zero volts between the hot wires. I then checked my double pole breaker and it was indeed sitting on just one phase. 30 seconds later the breaker was moved and now pushing out 240v!
The mobile charger now lights up :)
Now I just wait for the return of my Y...
Thanks again for your help
Reactions: ratsbew
