Hi All -
What is the current best solution for a 6-50 plug for temporary use? For whatever reason, the breaker is 40A. Is this common?
I'm going to pull either the plug or the circuit breaker box cover to check what gauge wire they used.
I'm expecting the worse case and probably should be selecting a lower amp setting.
What amp setting?
What adapter is best these days?
Thanks!
What amp setting?
Thanks!
