E90alex
Literally none of those apply the the OP, yet everyone is trying to peddle the wall charger.So the added cost is about $195-275, mostly dependent on the cost of the 14-50 outlet and GFIC breaker. So what do we get for the extra money?
Of course not all of these apply to everyone, so it may still not be worth it to many people.
- Charge at 40A instead of 32A on a 50A circuit. Charge at 48A on a 60A circuit
- The mobile connetor that came with the car stays in the car so it is not forgotten when needed
- The wall connector is waterproof so it can be installed outside
- It supports power sharing when multiple wall connectors are installed
- It receives firmware updates. Power sharing was added via a firmware update. Also added was the ability to lock the connector to only Tesla cars, or just to one car
The wall charger is $495 vs $45 for the UMC adapter and using the UMC that already came with the car. That’s $450 difference. Breaker cost and wiring cost is a wash since you would need a new breaker for either the wall charger or upgraded outlet.
1. He only wants to install a 40A circuit so it won’t charge any faster than the mobile connector.
2. Would be nice, but depending on usage habits would never need to use it away from home.
3. He’s installing it indoors
4. Not something OP is doing
5. That’s nice but as long as it can charge the car idk if a charging cable can update its own firmware or not.
The 48A charging is the main benefit, but even that is of minimal benefit. Most people only use a fraction of their battery in their daily driving and plug in overnight, so even a 16A EVSE would be more than sufficient to replenish the amount of used battery charge overnight.
