6 wheels bent now.. anyone else?
tritonx
32
0
Redwood City, CA
Have had the tesla for 16 months and in that span, we've had 6 bent wheels (right rear, right rear, then all 4 at once). We own 4 other cars and none of them have had bent wheels in the 7 years we've lived here. Anyone else experiencing bent wheels at all? we have the turbine silver 21" wheels.
anticitizen13.7
Not posting at TMC after 9/17/2018
Dec 22, 2012
3,638
5,761
United States
I'm not a Model S owner, but the 35 profile tires on the 21" rims don't offer much defense against road hazards. If the 21" wheels are giving you problems, is it possible to switch to the 19" ones? The taller sidewalls should be much more forgiving.
Lloyd
6,252
2,039
San Luis Obispo, CA
40,000 EV miles and no bent rims, and I have 21's ! S witch to 19's quick!!
That said, I realize the vulnerability and have a set of 19s for long trips where I don't know the roads as well.
AmpedRealtor
6,343
3,315
Phoenix, AZ
Nope.
UMD86
269
I was in the same boat as you but luckily I had the tire insurance. I had 2 blowouts at the same time at 1AM on I-80 (LF & LR). Had to replace both tires and 1 Rim. Since then I've had 2 more flats and a bent rim. I know the insurance company hated me but I bit the bullet and switched to the 19's.
I have 4 good tires (< 5,000 miles) and 2 Mint Rims and 2 with some Rash if you want them. Send me a private msg.
yobigd20
5,925
528
Skaneateles, NY
51k miles on 19" wheels (48k on original goodyears) never had a bent rim or blowout. Your on 21s. That's a very common problem for those 21s because there's such little sidewall you're basically practically driving on the wheel itself. If you hit even a small pothole that rim is bending for sure and tire likely getting flat too. Many many many owners after multiple bent rims and blowouts have switched to 19s. I highly recommend you do the same. Those 21s are for show only and are completely impractical for real world driving unless your pockets $$ are really deep.
trils0n
2013 P85
Feb 12, 2013
1,527
1,947
SF Bay Area
15k miles in 16 months with 21s. No damage. I work in RWC, so similar area to the OP. Are your tires kept at 45 lbs or whatever the recommended pressure is? Under-inflated tires will provide less protection.
AlMc
'When the music is on...you gotta dance' (Go Elon)
Apr 23, 2013
7,346
15,494
Delaware
15 months/16K miles P85+ with 21s...no problems and I have driven over some potholes that I though might cause me an issue..but no.
Panacea
TSLA Shareholder/Believer
Feb 9, 2013
231
0
NJ
10K miles on 21s with 1 flat and 1 tire worn to cords. Also 2 bent rims-both on the inside of the wheel. Time to jump ship to 19s.
Dborn
Confirmed
Aug 26, 2011
2,715
357
Sydney, Australia
On a sports car with low profile tires, hit a pothole coming off an expressway at slow speed, circa 10 miles an hour, bent rim, ruined tire!! That is the reason i specified 19's for my Tesla!!
flodrab
105
5
Venice, CA
I purposely did not get the Performance Plus package solely because I didn't want the 21" wheels ... most of my driving is in L.A., potholes are everywhere, and I didn't want such low profile tires ... but 19's look a little small to me, so I got a set of 20's ... I think that's the sweet spot, not too big and not too small ... 255/40-20 in front, and 285/35-20 in back
tritonx
32
0
Redwood City, CA
nice wheels flodrab! i think i do need to change to 19's. I do live in RWC but up in the hills and perhaps that has something to do with it, constantly changing grades where wheels will be on different planes such as our driveway vs the road. too bad performance plus wasn't an option in '13 ordering book! Thanks for comments everyone.
StephenM
1,192
93
21k miles. 2 cracked wheels. Both times I thought I just ran over a nail or something due to the slow leak. Took it in to have it looked at and they found the cracks in the wheel. Luckily I purchased the road hazard protection so they were replaced free of charge. The tires were still fine. We have a lot of potholes here on Oahu and I can mostly avoid them, but sometimes new ones pop up and BAM!
jerry33
Mar 8, 2012
19,525
21,731
Texas
While 35 aspect ratio tires don't provide a lot of protection, I'd be interested to know how many of you who have had damaged wheels check your tire pressures regularly (minimum weekly) and never ever,ever let them go below the vehicle placard pressure. That pressure should really be considered a minimum (not a maximum) for road use.
Bear in mind that if the highs of the day reach 38 (100 F), you need to add 4 psi just to compensate.
mknox
10,103
1,866
Toronto, ON
No problems here. I use the stock Tesla 19" rims with Nokian Hakka R2s in the winter and Rial Lugano 19" rims with the stock Goodyear tires in summer. A bit over 30,000 miles.
