60kwh range charge
Discussion in 'Model S: Battery & Charging' started by iridium, May 22, 2013.
  1. iridium
    iridium Member
    Scottsdale, AZ
    What rated distance have you seen on a 60kwh with a full range charge?
  2. Banahogg
    Banahogg Member
    San Jose, CA
    I've done a full range charge once since they fixed the reporting in 4.3 and it showed 207 IIRC.
  3. CaptDaveHowe
    CaptDaveHowe Member
    LI, New York
    I normally charge up to 180-185 miles on a rated charge.
  4. jomo25
    jomo25 Active Member
    Scottsdale, AZ
    Really? I swear I've gotten to 190 on a rated std charge. I've only done it once since I got the car, so I can't promise that, but pretty sure that was my number when I did.
  5. jandkw
    jandkw Member
    Cary, NC
    Charged 3 times and were between 207mi to 208mi.
  6. jomo25
    Scottsdale, AZ
    Sorry, I forgot to mention. I never have done a range charge, so I can't answer the original question.
  7. FredTMC
    FredTMC Model S VIN #4925
    Orange County CA
    I currently get 185 on a full std charge. I have 7,008 mi on odometer. I don't charge fully very often (std or range). I just charge up to what I need for the next day plus some buffer. The slider on v4.5 will be handy for me.
  8. jomo25
    Scottsdale, AZ
    Did a full standard charge again today. 190 miles. Though, as I started driving, it quickly dropped 4 miles after only about a mile of driving. But it definitely started at 190.
  9. Ven Rala
    Ven Rala Member
    Montgomery County, Md
    My usual rated standard charge is 190, but have seen 187-189.
    I will get a chance to do a range charge in a couple days, so will update then.
  10. Apoclyps
    Apoclyps Member
    Taipei, Taiwan
    My standard charge always stops at 190. For Range Charge (which I've done a few times) i normally get 206 from a 30A charger. Last night I did an overnight Range Charge on a 110v outlet in my garage and the car said 211 this morning.
  11. Alfafoxtrot1
    Alfafoxtrot1 Member
    Chicago
    Standard, 190 / Range 208
  12. Treker56
    Treker56 Member
    Fairfax, VA
    Yesterday did my 2nd range charge and got 209 right after charging complete. Standard is 190 consistent.
    1,000 miles on the Odo.
  13. Discoducky
    Discoducky Happy owner of a P100D X and a brand new 2021 M3!
    Seattle
    When stating range please note your firmware version (4.3, 4.4, 4.5 etc), how long after it completed charging you noted the range (vampire load), total Odo reading and ambient temperature.
  14. Iz
    Iz EVs are here to stay
    New York
    Have firmware version 4.4. Usual rated standard charge is 185-190. Did first range charge using the Supercharger in Milford yesterday. Max range was 210.
  15. Sshrivas
    Sshrivas Member
    San Francisco
    Have had Model S for two months now with about 2400 miles and firmware version 4.4. Standard charge goes to 190 miles and Max Range charge to 208 - 209 miles max. Have an email out to Ownership to clarify.
  16. Ven Rala
    Ven Rala Member
    Firmware:4.4, Standard:188-190, range:210
  17. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    The EPA rating for the 60 kWh Model S is 208 miles rated range so that seems right.
  18. shark
    shark Member
    chicagoland
    v4.5. Standard charge 190 consistently over the last 4 weeks and 1280 miles. "Accidentally" did range charge once to 210.
  19. SFOTurtle
    SFOTurtle Active Member
    Los Altos, CA
    I'm on v. 4.5, and did a range charge two days ago and it finished charging at 204. I have 7200+ miles on the odo. My standard charge on 4.5 is normally 180-82. Sigh, wish I could have seen the max on my car in the ranges others have reported. I do most of my charging between 30 and 40 Amps at home, but also use Level II Blink at the office a couple days a week. I've also used SCs about 5-6 times and used twin chargers on 70A about a dozen times since Feb.
  20. Ceilidh
    Ceilidh Member
    Los Gatos/Santa Cruz Mountains/Silicon Valley, CA
    I have about 4500 miles on my Odo and my numbers are similar to your SFOTurtle. I get about 206 for a range charge and 180-186 for a full standard charge with the slider to the far right of the standard charge choices. When I first got the car the range charge read 208. So I have seen a very slight decrease after 4500 miles. I too have used the Superchargers about 7 times or so. I use the HPWC at home currenbtly still at 60 amps most of the time but sometimes 80 when I need to charge faster.
    Cheers.
