A week ago I tested my powerwalls off grid and let my solar charge them all the way up to 98% before the frequency went to 60.4 Hz and the inverter shut off. It cycled a few times as the battery drained to low 98% and the frequency went down to 60.1 or 60.2 and the inverter would come on again. This repeated several times.
I did this test to see what would happen with my extensive Insteon lighting system. Out of some 200 devices, only 2 didn't respond to an ALL query at this frequncy.
Well today, I decided to burn some power off my 92% charge because I didn't want it just sitting there at that state all day long until peak hit and I was just itching to test backup mode again, so I turned the main breaker off.
All my lights inside instantly started flickering. I took a glance at the Kill-A-Watt to se 62.8 Hz. WTF????? Why did it the frequency go so high at only 92%????
Killed two of my Insteon switches. They're dead and won't even turn on locally by hand. Even though all my network equipment is on a giant UPS and it switched over to the UPS, all my Unify equipment had to be rebooted to restore all my wifi APs to working order. Basically the frequency wrecked havoc with all of my sensitive equipment.
The only difference that I know if is that my power walls just updated from 1.50.1 to 1.50.2
