It was perfect from 4.2 to 7.0
This is a new feature... auto
brightness (changing the %) didn't exist before recently. (auto day/night did) They are adding a feature, that is awesome in theory, if the sensor reports "light level" in a 0-100% capacity with, for example, at least a 10% or less margin.
But the original design only called for a night/day flip, where a cheaper light sensor that may have a larger margin of error (and lower cost) may have worked (and will continue to work, in that capacity) just fine. Similar to the light sensor on my motion lights outside my house... they don't need to know, down to the 1% of dark vs. light... they just need to know, is it day OR night? Not a specific
level of light.
Does that make sense? it's the different between asking "is it light" and getting a Yes/No or "77%" as an answer. So I question if the sensor I have, from 2013 can answer that question.
Or maybe the sensor is sufficient, and the car's just buggy
I'll give it another go since I've had 2 updates since it was first released. On mine, instead of "learning" from me, it would just do what it wanted, even after I set a level, it would auto adjust 5 min later. (and after 3 tries of fighting the machine, I turned it off).
