Could it be that the tow hitch makes the difference? I mean cars with tow hitch can load more than without? Mostly a question here
I live en Denmark, and just realised that the car is registered with a max total payload including the driver of 390 kg.
You will fined if you are pulled over for a weight check and you exceed this limit.
Two adults and two teenage boys easily add up to 340 kg, leaving 50 kg for luggage??
If you add the tow hitch kit, which cannot be bought in Denmark yet, then you will add additional weight to the vehicle, further reducing the amount of usable payload.
In Denmark the rule is that the weight on the hitch (typically 80 kg) must be added to the cars payload.
Assuming that the high strength towing bar kit weight 20 kg, then we end up exceeding the weight limit in multiple cases, which seems crazy.
Let’s say an adult weight 85 kg and teenage boys weight 70 kg, just to be conservative, then we will have a passenger weight of 310 kg. Add to that the 20 kg of the tow bar with hitch etc. That leaves 60 kg in total for other stuff.
If you use a caravan you will exceed the limit without even adding a single kg of luggage in the car.
If you need to go to the airport for a travel, bringing standard 20 kg of luggage each, you are heavily exceeding the limit.
You will for sure not be able to go skiing as the weight of the ski box, skies etc exceeds the 60 kg alone.
Going on summer holidays with a total of 60 kg of luggage seems close to impossible.
It seems to add up to a conclusion saying that TMY is not a family car, unless you only have small children, and pack carefully.
Such a shame. I have ordered the car, but are seriously considering cancelling, as the TMY was meant as our primary car.
