Have a new Model S 70D. Did not go with the upgrade to the 75.
Only getting a full charge around 230.
Pretty sure it's supposed to be 240 - anyone have any suggestions?
Thanks
Some say it takes into account how you drive. ??? AC on, fast starts and the like.I was using the Daily charge and it seemed low. It was suggested to let the battery run low and do a full charge to the Trip limit, like a cell phone. Have not seen a change.
That is only the case for the projected range value. Rated range is basically just the calculated pack state of charge divided by the EPA's energy consumption rating in wh/mi. Small fluctuations in rated range are generally due to the way in which the software is calculating state of charge.I do believe your driving style effects the range calculation.
I get only get 213 when set to daily and have not used the trip setting. I know it's a 75 and setting it to Trip shouldn't hurt but I don't need the range.
For me its simply a case where we should be getting the correct charge and range per the specs we ordered. I expect to use more juice up in the summer with AC and fans; but would the total range be affected when fully charged? I'm trying to find the specs for the 70D but they are no longer on Tesla's website since changing to the Zm
I got 234 on my one range charge on a 70d...haven't run the battery below 140 yet though. It's summer and I consistently run the air and on city roads and am getting 10% to 20% less mileage than stated...think this is pretty normal. Range goes up when I do more freeway driving. 90% was 210, now 214.
So may I ask, was it recommended to keep charging whenever ywe you can (you say you don't get below 140); as opposed to let the battery run low then charge, much like a cell phone or battery? Is there a formal recommended protocol? My service guys, normally great and responsive,dlmllltt have not responded in weeks, may just be hoping I let this go..
Just as a reference point, I've had the car less than two months, bought new.
I'm wondering how much time everyone's decline in total capacity took place in.
Thanks for everyone's input.
