70D vs. 85 in HP and zero to sixty
Discussion in 'Model S: Driving Dynamics' started by donaldp, Apr 12, 2015.
  1. donaldp
    donaldp Member
    San Diego, CA 92120
    The 70D has 329 HP and goes zero to sixty in 5.2 seconds per the latest upgrade to the order website. The 85 has 362 hp and goes zero to sixty in 5.4 seconds. This makes no sense to me. Can someone explain or is that inaccurate?
  2. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    Traction. Power to weight.
  3. Stoneymonster
    Stoneymonster Active Member
    Aptos, Ca
    Also, the 85 was always sandbagged in the Tesla specs. I think people were getting closer to 5.0.
  4. Thud
    Thud Member
    Atlanta
    S85 gets around 4.9 in real world testing. I think the rated performance specs are mostly just marketing to persuade people to go with a dual motor car. I would suspect that the 70D and S85 will be essentially identical in actual testing.
  5. invisik
    invisik Supporting Member
    Minneapolis
    I hope the S85 is over-rated.... else it stinks! :)
    -m
  6. 3mp_kwh
    3mp_kwh Active Member
    Boston
    I think the S85 also went up, on the website, from 5.2, to 5.4. If the 70D matches the 85, I'd bet we see a faster 0-30, and a slower 30-60. The 60kwh car had worse roll-on, with real world 0-60 around 5.9 seconds. With battery size comes discharge and power potential. If you're planning on giving up 15kwh, of that 25kwh difference, don't plan on it coming without a sacrifice, in more than just range.
    I think the easiest way to remember Tesla's fading RWD history is 5.9, 4.9 and 3.9, for each P, 85 and 60.
  7. samcarney
    samcarney Sam C
    Great Lakes, Sonoran Desert
    I suspect there is less intervention from traction control with all wheel drive.
