Here's the post:
Pack Swap on 70D to 90kWh HP?
And see this post: Pack Swap on 70D to 90kWh HP?
If the difference is pure software, I wonder if Tesla could have turned every CPO car into a P model, and sell for a higher margin?
If the new packs are 75s versus 70s by utilizing less blanks, then how much extra weight would an MS with the 75 be carrying around not utilized? Enough to impact range a bit over time, e.g. an extra 100-200lb or so?
didn't they turn on super charging on all the CPOs? I wonder if there was any early software limited 40 cars got traded in and turned into CPO 60s.
Obviously not the relevant threads. I thought wk057 wasn't posting his research to TMC anymore. What thread(s) is this? I'd surely like to catch up, but I find it very hard to believe this is true just because wk057 makes one assertion about it. I'll believe it if/when he can "unlock" an S85 into a P85.
In case you don't stumble upon it in those posts....
Not ridiculous at all. This is just supply chain management. The people who bought 70s got what they paid for whether it is "true" 70 or a limited 75. This is no different than the S40 getting a 60kWh pack and paying a 40 price with a software limit.
Just as long as the 75 doesn't increase the weight over what the 70....
Gull wing doors #1Because at Tesla, "Communication is Job #856,422"
No it doesn't
Larger capacity battery but the same weight? Are you sure?
The battery chemistry has changed. Same way tesla went from 85 to 90 by adding silicon. Same number of cells. Same weight
Even if it weighs slightly more, you get better C-rates (and thus better life and charging speeds) out of it. Plus you get the option to upgrade it.Just as long as the 75 doesn't increase the weight over what the 70....
Given the amount of cells is the same and it is just a small chemistry tweak. Even comparing the lower capacity NCR18650A (45g) to the newer partial silicon NCR18650GA (47-48g), there is only a difference of 2-3 grams, so at 6216 cells that is still only 12.4-18.6 kg.I hope you're right. Bjorn thinks the extra capacity would add up to 30kgs quoting his latest video. No small amount if he's right. All guesses at this point until more info comes through I suppose.
