75 kWh remaining on a 90 kWh battery after 5 years, your thoughts?
cousin_IT
167
127
Netherlands
I bought a P90DL that just turned 5 years old with very low mileage (28.000 kms or approx 17,000 miles). The battery pack is a 1063792-00-A (90kWh, 400 VDC). Doing the math on the available energy in the car (according to this site) gives me 75 kWh of user available capacity. If the original capacity was 81,8 kWh that meas the battery degraded about 8,4%. Am I doing this right?
I've read that the version A 90 kWh batteries are not that great etc etc but I'm curious what this means in practice:
  • How big is the chance that this battery will fail?
  • Since the car didn't do a lot of mileage could the numbers be off and if so can they be reset?
FYI I'm not interested in getting my battery replaced, the environmental impact for creating 1 was big enough already. I would like to better understand what these numbers mean in practice. Thanks for your insights.
Droschke
2,402
4,300
Future
Using the same calculation, I've an average of 12.2% degradation for my car (Info in my signature). Should add that my car is also capacity capped.
Droschke
2,402
4,300
Future
I noticed the website you are referring to in order to do your calculation is a bit confusing when it comes to give you an example (the calculated values are not entirely matching). Use a similar method described @ Sudden Loss Of Range With 2019.16.x Software under CALCULATION OF AMOUNT OF CAPACITY\Method. Assuming you now have the total capacity of 79kWh (75+4), you have degradation of 8% (1-(79/85.8)), with 85.8 being your total capacity when your car was new.
cousin_IT
167
127
Netherlands
The devil is in the details, thanks for pointing this out. So 8% it is then. AFAIK 90 kWh batteries were not capped. Based on the responses I get 8% seems to be an OK value, thanks everyone for replying.
Reactions: Droschke
Blu Angel
280
259
Mississauga, ON, Canada
8.4% loss in 5 years sounds totally reasonable/not bad at all to me. My model 3 lost 7% in the first year.
I do not think your car is on track for premature battery failure.
@cousin_IT ,
Completely agree with cypho comment.
8.4% loss over 5 years is great!
The battery degradation of Tesla 90 & Tesla 85 loses 10-15% at 150,000-200,000 miles
Check out the graph in the following link
Tesla data shows battery degradation is limited but not all packs are created equal - Electrek
Reactions: CyberGus
hcdavis3
HCD3
Mar 3, 2019
1,814
1,058
02571
My 2020 model 3 has lost 6% in 5 months. Most say that’s normal. Not sure I buy that.
hcdavis3
HCD3
Mar 3, 2019
1,814
1,058
02571
Do you always charge to 93% like that? Doesn't your car warn you when you charge higher than 90% that it is not good for the battery? Your car's probably fine, but if not it might be because of frequent charges beyond 90%.
Rarely do I charge to that SOC. Only the last two times. Usual charge is to 80%. Only one supercharge, the day I picked up the car in June.
