75D battery degradation
Discussion in 'Model S: Battery & Charging' started by Drlev, Mar 13, 2019.
Tags:
  1. Drlev
    Drlev Member
    Harrisburg, PA
    I’m curious what sort of degradation people have seen on their 75Ds.
    I’ve driven 21,000 miles on my Dec 2017 build and my rated range is down to 240 miles at this point. This is down from 245 in the last 1000 miles driven. Per Remote S, I have 68.6 kWh usable. Does this seem normal or excessive?
    Anyone else care to share?
  2. ucmndd
    ucmndd Well-Known Member
    There are many threads on this issue in this section. I’d suggest starting with a search and reading them.
    If you want to cut to the chase, you’re not the only one. Several folks, myself included, have observed range loss of 7-10% on the 75 battery.
  3. houstonian
    houstonian ಠ_ಠ
    Houston. Duh.
    Took delivery of a new software limited S60D in Jan 2017.
    100% range of my S60D - which I consider to be the same as an 86% charge on an S75D - was 218. (This also implies a 253 rated range if my car was delivered as an S75D.)
    Since I took delivery I have unlocked the battery from 60 (i.e. 86%) to 75 (i.e. 100%) and my current 100% charge range is 237 as an S75D.
    86% of 237 comes to 204, suggesting a 14 mile, or 6.4%, battery degradation based off the 100% range at delivery of the software limited S60D (or 16-mile degradation of 6.4% based off the implied 253 S75D rated range).
    Current mileage on my car is ~69k.
  4. BANKWUPT
    BANKWUPT Member
    Bay Area, CA
    FWIW, I treat my 75D pretty badly compared to other people on this sub (charge to 90% even when I am not going far, charge to 100% once a week, use superchargers 4-5 times per week, have let the battery get down below 5% three times, have left the car parked overnight with less than 10%, etc) and have only "lost" 1 mile of range. When I got my car new in September 2018 it had 8 miles on the odometer & 100% charge was 252 miles. I'm at 8,900 miles since then and it charges to 251 miles. I don't think anyone knows, honestly. BMS can be weird.
  5. ucmndd
    I suspect that some time after the 100kwh battery pack introduction the 75 was switched over to the newer chemistry (and seemingly much more reliable) cells used in the bigger pack.
    The earlier 75 seems to have a higher rate of issues (just like the 90 did vs the 100).
  6. DOCAL
    DOCAL Member
    San Jose, CA
    Early face-lift S75D, 90% was 230 when new, now down to 218. 32K miles on the clock.
  7. rypalmer
    rypalmer Active Member
    Canada
    What's your max Supercharging rate in kW?
  8. ucmndd
    I still hit about 95kw under optimal conditions at 72k and ~10% reported degradation.
  9. DOCAL
    DOCAL Member
    San Jose, CA
    It's been a while since I've used one, guess I need to go on more long trips. Peak was around 95-96 last time though.
  10. A-Wimoweh
    A-Wimoweh Member
    Jungle
    I thought if you charged a brand new 75 to 100%, it would have a range of 259 miles?
  11. AAARSINIC
    AAARSINIC Member
    Carlsbad, CA
    I have 40,000 miles on my December 16 75D. 100% is down to 241 miles.
  12. ucmndd
    That was the original rating for a 75D, yes.
  13. Drlev
    Drlev Member
    Harrisburg, PA
    Yes, and few cars ever really reported that range even when new. When my car was new it maxed out at 254 miles.
  14. danieltyates
    danieltyates Member
    Los Angeles
    My 2016 s 75 only gets about 170 real miles on a full charge. Took it in, and they said I supercharge too much. Checked the warranty and it said there is no warranty on battery milage loss over time, of any ammont. I'm pretty bummed that I have to do a full charge, or two partials, while on a 250 mile trip to vegas from LA, instead of nonstop.
  15. Krash
    Krash Data Technician
    Intermountain US
    How many miles do you have?
  16. ttran203
    ttran203 Member
    Bay Area, CA
    I’m also curious about what your charging patterns looks like. And how many times do you supercharge per week?
  17. ucmndd
    +1 more info.
    Mileage, range at 100% charge, typical charging patterns?
  18. 3mp_kwh
    3mp_kwh Active Member
    Boston
    Sometimes the problem goes up, as the post counts goes down.
    I tend more to think, having read some of the threads, that 75D never should have been rated at 259miles. Ours is mid 230's, 100% charged. So, I don't believe its a problem battery, like some of the P90Ds. Tesla's dual drive ratings were touted a bit too much, when they started, maybe?
  19. ucmndd
    The rated range is measured battery capacity divided by a constant. So the only way that displayed number goes down is if Tesla changes the constant or algorithm in a firmware update (possible, though unlikely to make a significant difference unless they also change the EPA ratings), or if the measured battery capacity is less than it was before.
  20. danieltyates
    danieltyates Member
    Los Angeles
    40k
