79%
Discussion in 'Model 3: Battery & Charging' started by ttdanimal, Jan 5, 2020.
  1. ttdanimal
    ttdanimal Member
    Cleveland, OH
    I have nightly charge limit set to 80%.
    But it always shows 79% after reaching 'complete'. It's not a big deal to me. But I am curious if that's normal.
    (and yes, I know I could just set at 81%!! :D)
  2. antoinearnau
    antoinearnau Active Member
    Montreal
    Is your car sitting in a cold place ?
  3. ucmndd
    ucmndd Well-Known Member
    If your car finishes charging many hours before you start using it in the morning, then it’s losing some charge to cooling and vampire drain before you depart.
  4. ewoodrick
    ewoodrick Well-Known Member
    Buford, GA
    Normal.
    Battery voltage will fluctuate after charging and temp changes
  5. hugh_jassol
    hugh_jassol Member
    Los Angeles
    If it's below about ~55F or so you will "lose" about 1% off the capacity until the battery warms up. This is normal.
  6. ttdanimal
    ttdanimal Member
    Cleveland, OH
    Thanks all. I am in cold right now. All makes sense.
