You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
I have a 2020 MX UK Spec and have just realised that despite having a 7KWh home charging point my X only charges at 3KWh so at 9 miles an hour max ever. Now I have a smart meter and can confirm that the draw is never more than 3 KWh!
I rang the Charge point installer and they have said the issue is the Tesla limiting the amps and I needed to increase the limit but I can't seem to get any more than 16 using the on screen slider.
Does anybody have any other ideas. The point is a Pod point 7KWh Untethered and my cable is a 5mtr Rolec type 2 and I also have a Ohme lead and the same issue occurs with either!
Any thoughts as to why the limit is stuck at 16 when it should be 32 or even 40 amps apparently?
