8.0 Homelink(Garage) make a noise when approaching ?
Discussion in 'Model X' started by vv132, Oct 15, 2016.
Tags:
  1. vv132
    vv132 Member
    NJ
    Hey so in the 8.0 release notes it stated that homelink makes a noise when the car is approaching the garage. Is this happening for you guys? All that happens in mine is that the garage icon pops up same as before 8.0.
    Thanks
  2. Branzo90D
    Branzo90D Salt and Pepper
    NorCal
    I do get an audible beep when the HomeLink transmitter signals to open the door. I do not remember that happening before 8.0, but as my wife says, I suffer from CRS disease. :rolleyes:
  3. Merrill
    Merrill Active Member
    Sonoma, California
    Yes, if the signal is sent then it makes a beep telling you it is opening. I like this because sometimes before 8.0 I was not sure it sent a signal. They still have not got the homelink to work when you have a gate and garage door, for me only one will open and close at a time. I have given up on resetting the location done it in all configurations and still only either the gate or the garage door will open or close.
  4. mjeagent
    mjeagent Member
    Northern Virginia
    In concept this was a good idea. Until getting fully used to the beep I will sometimes brake thinking it's the backup camera. Maybe a chime/beep that is not in any way similar to the backup noise.
  5. NOLA_Mike
    NOLA_Mike Grouchy
    Hammond, LA
    If the audio system is playing too loud you won't hear it...
  6. Xminus6
    Xminus6 Member
    Bay Area, CA
    Yep. I like the audio notification but it should be different than the parking sensor sound. I don't know why they would make them the same as the parking sensor sound should ONLY be used for that purpose.
  7. MorrisonHiker
    MorrisonHiker S 100D 2019.20.4.2
    Colorado
    You have to enable the automatic Homelink option in order to hear the beep. If you still operate it manually, then it figures you know that one of the buttons was pressed and doesn't bother making a beep.
  8. vv132
    vv132 Member
    NJ
    Thanks! this helped me out, didnt notice that option . Thanks!
