8.0, iOS 10, iPhone 7 and Personal Hotspot
Discussion in 'Model S: User Interface' started by rallykeeper, Sep 27, 2016.
  1. rallykeeper
    rallykeeper Member
    Southern California
    Has anyone successfully connected their 8.0 Tesla to their iPhone 7 personal hotspot?
    My classic S85 was connecting flawlessly on 7.1. Updated to 8.0. Can't connect.
    I've rebooted everything, forgot networks -- all the usual tricks.
    Nothing. iPhone sees the hotspot network and gets stuck on the connecting screen.
    (Haven't been able to test my home network yet, so I'm not sure how pervasive the issue is).
  2. Boatguy
    Boatguy Member
    SF Bay Area
    Did you mean to say "Tesla" sees the hotspot network but gets stuck connecting?
  3. rallykeeper
    rallykeeper Member
    Southern California
    Yep.
    Can't seem to edit my original post to fix.
  4. pdxgibby
    pdxgibby Software Engineer
    Tualatin, Oregon
    Same problem for me. Worked fine on 7.1, but cannot connect in 8.0. :(
  5. MikingCO
    MikingCO Member
    Colorado Springs, CO
    Connects on my 7 plus running iOS 10.1 beta but I have to try a few times to get it going.
  6. ICUDoc
    ICUDoc Member
    Sydney NSW
    [email protected] Probs cant help you, but I tried to connect to my new iPhone 7 (which has the same name as my old '6). Of course, telling it to connect to "Administrator's iPhone" didn't work- I was mystified for days. Then I realised I needed to "Add New Device", as its a new phone, not the same phone.
    hard to believe I run a major hospital department....
  7. rallykeeper
    rallykeeper Member
    Southern California
    Tested WiFi at home and that worked fine. It seems to be limited to my hotspot.
    I don't think it's an iOS issue since I had this exact same phone working with TeslaOS 7.1 (I like the ring of that name ;)).
    Just doesn't work now with TeslaOS 8.0.
    I'm guessing it has something to do with security, but I can't figure it out.
  8. GaryREM
    GaryREM Member
    Fairfax, VA
    Tesla 8.0 connects to my iPhone 6 with 10.1 beta hotspot with no issue. Suspect there may be a bug in 10.0.
  9. Boatguy
    Boatguy Member
    SF Bay Area
    I connected to an iPhone 7 with iOS 10.0.2 with no problem.
  10. mnewman
    mnewman Member
    Houston
    I had to remove the network and re-add it. Then it worked. Had to remove and re-add the iPhone in Bluetooth after the iOS10 upgrade as well. Obviously it's not a wide-spread problem or we'd see more threads about it, but it DID affect me, but luckily it was a relatively easy fix. Good luck....
